Peter1000
#1 Posted : Tuesday, October 6, 2026 1:54:40 AM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
A small program that detects your DeckLink card in your computer (Blackmagic driver required) and then converts the input signal into an OMT stream. In this form, it supports only 720p50/60 and 1080p50/60, with 4 stereo pairs or 8 mono channels (put on 1&2).
Full code and setup are available on GitHub.
My program is licensed under the MIT License; please note the separately listed OMT license terms.
SDI2OMT
GitHub Link
ClickOnce setup included (read.me:-)
thanks 1 user thanked Peter1000 for this useful post.
jet on 10/9/2026(UTC)
Peter1000
#2 Posted : Wednesday, October 7, 2026 4:22:34 AM(UTC)
Peter1000
Switzerland
updated, 1.0.0.7
-fixed bug in the connection display
-supports now also 1080i50/i60
-Blackmagic Card & Status Info
-Reconnection has been thoroughly tested; the signal usually returns after a second, even when switching from low to high.
jet
#3 Posted : Thursday, October 15, 2026 3:52:08 PM(UTC)
jet
Was thanked: 29 time(s) in 27 post(s)
Great program!
Why it is called SDI2OMD CONVERTER and not SDI2OMT CONVERTER?
And I hope there will be soon OMT2SDI CONVERTER/DECODER also :)
Kind regards,
Jani
Peter1000
#4 Posted : Thursday, October 15, 2026 8:54:00 PM(UTC)
Peter1000
Switzerland
Those who can read and write are really lucky :-)
give me some time..
jet on 10/15/2026(UTC)
