Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 85 time(s) in 65 post(s)
A small program that detects your DeckLink card in your computer (Blackmagic driver required) and then converts the input signal into an OMT stream. In this form, it supports only 720p50/60 and 1080p50/60, with 4 stereo pairs or 8 mono channels (put on 1&2). Full code and setup are available on GitHub. My program is licensed under the MIT License; please note the separately listed OMT license terms. GitHub LinkClickOnce setup included (read.me:-)
updated, 1.0.0.7 -fixed bug in the connection display -supports now also 1080i50/i60 -Blackmagic Card & Status Info -Reconnection has been thoroughly tested; the signal usually returns after a second, even when switching from low to high.
