Joined: 11/14/2012(UTC) Posts: 381  Location: Finland Thanks: 240 times Was thanked: 29 time(s) in 27 post(s)
Hi Xavier!
Would be really important to be able to use Image stabilization on OMTake. Now with V1.4 its very hard to get a decent video from a hand held iPhone.
Enabling Image stabilization would also increase the video delay and/or crop the video? if so, then this should be an optional setting.
Would also be essential to be able to set White Balance, HUE and Exposure adjustments = Exposure Compensation.
Kind regards, Jani
 1 user thanked jet for this useful post.
Joined: 8/18/2025(UTC) Posts: 9  Location: France Thanks: 11 times Was thanked: 6 time(s) in 6 post(s)
Hi Jani, Thanks for the feedback. Image stabilization will be available in OMTake 1.5, which should be released by next week. You're right that it comes with a trade-off: enabling it adds some latency and a slight crop of the frame, so it will be an optional setting you can turn on or off depending on your setup. Version 1.5 will also add manual image controls: white balance, hue, and exposure compensation. I'll post here as soon as the update is out. Kind regards, Xavier https://omtake.app/
 1 user thanked xcapetir for this useful post.
