#1 Posted : Monday, October 27, 2025 2:36:24 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
vMix 29 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Feature Requests
All feature requests should be submitted in the dedicated forum: https://forums.vmix.com/topics/4-Feature-Requests
Thanks,
thanks 8 users thanked admin for this useful post.
QuiapoChurch on 10/27/2025(UTC), monamiga on 10/27/2025(UTC), alexis.cordoba on 10/27/2025(UTC), eduardocfs on 10/27/2025(UTC), ryxyz on 10/27/2025(UTC), jet on 10/27/2025(UTC), MattiaCC on 10/28/2025(UTC), AngusFindlay on 10/28/2025(UTC)
g7pfv
#2 Posted : Tuesday, October 28, 2025 8:04:09 AM(UTC)
g7pfv
Replays appear very pixelated when LQ is selected - looked fine in v28 with same settings.
#3 Posted : Tuesday, October 28, 2025 2:47:59 PM(UTC)
Thanks for the report, the LQ is now fixed as of 29.0.0.35
monamiga on 10/28/2025(UTC), g7pfv on 10/28/2025(UTC)
leninhn
#4 Posted : Wednesday, October 29, 2025 3:54:11 AM(UTC)
leninhn
Honduras
Hello everyone. I apologize for the lack of English, as I'm using the translator.
I just updated to the new version of Vmix 29 and I'm having an issue with the audio in some movies MKV. In some, the music and sound effects are very loud, but the dialogue is almost inaudible.
Also, in this version, I can no longer use the K-Lite codec to change the audio or subtitles in movies.
Has anyone else had this issue? Do you know of a solution or workaround?
Thank you very much in advance!
#5 Posted : Wednesday, October 29, 2025 8:38:41 PM(UTC)
The default decoder for MKV files was changed in 29 to the built-in FFmpeg.
This is because many of the handlers for this format, including in codec packs are notoriously unreliable and can even cause random crashes, so we obviously want to avoid that.
That said, if you want to take the risk, and go back to the Windows codecs for MKV decoding, simply remove the *.mkv extension from Settings -> Decoders -> FFmpeg
leninhn on 12/7/2025(UTC)
bd9565
#6 Posted : Thursday, October 30, 2025 2:15:54 AM(UTC)
bd9565
Netherlands
When I change input content (for example from one picture to another one, or to the camera), the category of input has changed. Coloured cog became grey. It is so inconvenient. Please return input category retain, like it was in 26 version of vMix.
#7 Posted : Thursday, October 30, 2025 2:28:33 AM(UTC)
Can you please provide step by step instructions on how to replicate, as I did some tests just now changing the input that was assigned to a particular category, and that category stayed the same after the change, it did not revert back to default/grey.
bd9565
#8 Posted : Thursday, October 30, 2025 1:12:02 PM(UTC)
bd9565
Netherlands
Hmmm... You are right. The color of cog has not changed today. But I do remember that I met this problem before. Please give me some time to investigate this issue more thoroughly ... Thank you.
aircooled76@gmail.com
#9 Posted : Friday, November 21, 2025 4:07:51 PM(UTC)
Thanks for the updates.
I am having an issue with the vMix Replay tagging drop down menu. It makes a drop down of all tags so far, but as far as I can see I can not write directly in the field to tag a clip. it ALLWAYS auto completes to something previously. I think this is a bug.
In our case we tag clips with X, XX, XXX or XXXX plus a descripter. If you tag the initial clip with XX Good throw, then want to tag a clip with XX only, it is imposible for it not to be XX Good throw as it auto completes.
Would be great to have the option to turn of the tag list function too. Not useful for all workflows.
#10 Posted : Friday, November 21, 2025 8:26:05 PM(UTC)
Right click at the location you want your text to go (you will also get a dropdown but can freely enter text of your choice), not choose from the top dropdown list
#11 Posted : Sunday, November 23, 2025 8:11:02 PM(UTC)
We have just released an update to hopefully improve this in 29.0.0.40
What was happening is Windows would auto match the nearest entries when the dropdown was open, leading to certain text entered not updating properly.
This should be better now.
aircooled76@gmail.com on 12/24/2025(UTC)
kross
#12 Posted : Wednesday, November 26, 2025 5:49:16 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
I seem to have lost the ability to record multiple audio tracks (more than 3 stereo busses) to WAV files when recording. Previously I would record all the audio busses to WAV file, even though the mp4 file couldn't handle that many audio tracks. No problem, the wav file had all the audio tracks, and I edited in Davinci Resolve no problem. Now in 29, it just refuses to even create a WAV file if there are more than 6 audio tracks (3 stereo busses) because it says mp4 can't handle it. So now I get no audio recorded at all, whereas in 28 I would get audio recorded to a WAV file.
#13 Posted : Wednesday, December 24, 2025 2:16:12 PM(UTC)
Thank you, functions as expected now, thank you!
Luis70
#14 Posted : Wednesday, December 24, 2025 9:56:14 PM(UTC)
Luis70
Grenada
I have decided not to use winsdows 11 for vMix as yet...I am using windows 10 Enterprise LTSC, a version that comes without all the Blotware, and it works wonderful....no lot of updates that adds causes issues...a clean OS
tnorrell
#15 Posted : Thursday, December 25, 2025 11:01:10 AM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
I support your choice, and the logic behind it is sounds, but for what it's worth, I've been using vMix on my win11 machine for over a year, and have had zero issues. I'm not exactly sure what you're calling bloatware, but I honestly never see unexpected content on my box.
Luis70
#16 Posted : Thursday, December 25, 2025 12:57:46 PM(UTC)
Luis70
Grenada
Then you should check up on it....search the net and you will see what I mean ... LTSC does not come with all those added unwanted software lik xbox, games and such things tha run in the backgeround and use up valuable resourses...has tighter security and it runs smoother... it is windows 10 for business and it is much lighter....go do a search on google or youtube and get a better understanding about it..
(Windows 10 LTSC (Long-Term Servicing Channel) is a special version of Windows 10 Enterprise for dedicated devices needing stability, offering long support (5-10 yrs) with no feature updates, excluding the Microsoft Store and bundled apps, ideal for critical systems)
BrucieCam
#17 Posted : Tuesday, January 27, 2026 3:57:01 AM(UTC)
BrucieCam
Hi, I dont know if this is just on my system, but I've updated to 29.0.0.45 and mixminus on my microphone doesnt work. I rolled back to 29.0.0.40 and it was fine. Went back to 29.0.0.45 and i can hear myself again. Went back to 29.0.0.44 and its good there too.
Just a heads up if you experience the same.
jet
#18 Posted : Monday, October 12, 2026 3:40:24 AM(UTC)
jet
Was thanked: 27 time(s) in 25 post(s)
vMix 29.0.0.49 OMT (&NDI?) Source Discovery is Buggy
The emitting source is not discovered!
I can reproduce this issue.
Here how to reproduce it:
Have vMix open and add an OMT stream to it. In my case I stream from an iPhone with OMTake V1.4.
Save the project in vMix.
Shut down vMix PC.
Shut down the WiFi router which is taking the OMT stream from the iPhone.
Let the iPhone continue to stream.
Power up the vMix Pc.
Start vMix and load the saved project.
Power up the WiFi router.
------> vMix won't recover the OMT stream from the phone!
Utilities like "OMT Tools Studio Monitor" DOES find the stream - vMix not.
And the strange part is that if vMix is then quitted and then re-launched - it works..
What gives??
pm
#19 Posted : Monday, October 12, 2026 5:08:11 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi
I've seen a similar issue with NDI in the past. Not a solution for the issue.
If a NDI encoder does a reboot and gets a new IP address, vMix discovery held the old entry for some time until it's updated. If you select the source to early, black picture could be the result (because of trying to connect to the old IP). Restarting Vix initializes the source list.
Would love to have a "reset discovery list" button.
Best regards,
Patrick
