I have a situation with our setup, which developed after a deluge of Windows 11 updates. The Behringer Interface will only load once to get sound when you next start the computer you have to uninstall and then re install the Behringer driver. Google suggested turning off exclusive Mode which I did but with no improvement. Should anyone have had a similar problem I would be most grateful for some advice. Simon
This sounds more like a "Behringer" driver problem than an Exclusive Mode problem. I would check if Windows 11 is overwriting the driver after a reboot and also disable USB power management. If we knew the exact interface model we could narrow it down.
Joined: 11/23/2020(UTC) Posts: 251  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Originally Posted by: Simon Wilson  I have a situation with our setup, which developed after a deluge of Windows 11 updates. The Behringer Interface will only load once to get sound when you next start the computer you have to uninstall and then re install the Behringer driver. Google suggested turning off exclusive Mode which I did but with no improvement. Should anyone have had a similar problem I would be most grateful for some advice. Simon Are you using ASIO drivers, I have a Midas M32 with a Klark Teknix DN-32 Live card plus a Behringer UMC204HD and both of them use the ASIO drivers and I have to restart the PC after every cold boot because the PC assigns different numbers to the 6 monitors attached on the cold boot versus the reboot and I need the assigned numbers as the reboot gets them but vMix has no trouble connecting to either. Also running Windows 11 and am up to date on updates.
