Simon Wilson
#1 Posted : Friday, May 29, 2026 10:39:08 PM(UTC)
Simon Wilson
I have a situation with our setup, which developed after a deluge of Windows 11 updates. The Behringer Interface will only load once to get sound when you next start the computer you have to uninstall and then re install the Behringer driver. Google suggested turning off exclusive Mode which I did but with no improvement.
Should anyone have had a similar problem I would be most grateful for some advice. Simon
sarah45
#2 Posted : Thursday, June 18, 2026 8:24:57 PM(UTC)
sarah45
India
This sounds more like a "Behringer" driver problem than an Exclusive Mode problem. I would check if Windows 11 is overwriting the driver after a reboot and also disable USB power management. If we knew the exact interface model we could narrow it down.
