Joined: 2/23/2023(UTC) Posts: 94  Thanks: 30 times Was thanked: 20 time(s) in 6 post(s)
It's only day 1 of a five day show. It may take a bit for any reporting to get out to the public.
- Tom
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
I mean, you just go to the booth and say what you saw there.
It's not something that really takes time--just a willingness that most people don't seem to have.
Even in the past when people have explicitly said "I'm going on this day and I'll report back" within the various vMix communities, they haven't.
When I say the vMix news out of IBC is generally limited to StreamGeeks and the vMix live stream, I'm not exaggerating.
And StreamGeeks usually published on Day 1, if I recall correctly. And their website and YouTube channel has had a lot fewer updates than usual over the past year.
I maybe I can report, going Monday ;-)
Joined: 5/14/2018(UTC) Posts: 115 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Was there today and I like the new features. Tempted to not spoil it for Vmix Funtime Live show
All Ill say: updates are worthy of a version jump
- Maximum number of replay cameras to 16 - Can import clips to a replay channel - 10, 12, 16 channel replay multiviews - More replay APIs - Increased outputs to 8 - Updated Chrome Browser version - Slideshow input presenter mode - Built-in powerpoint support - Mousewheel scroll for lists - GT Titles: Inverted mask support, copy properties between elements, change multiple text fields at once, eye dropper tool - More list information (e.g. total list duration) - More list shortcuts/APIs - Data source formatting support for numbers, dates - Tally pass-through for mix inputs - Message support for production clocks - More multiview layouts/options - New overlay designer w/ effects support (shapes, borders, rounded borders) - SRT updated to latest version - Support SRT as stream output - Decklink 8-bit to 10-bit convert - Audio effects (RNNoise, RTX Audio Effects) - New free 'vMix iO' software for Windows, Linux to convert SDI to OMT
 8 users thanked ryxyz for this useful post.
Peningkatan Replay:
- Kapasitas 16 Kamera: Dukungan hingga 16 input kamera untuk instant replay. - Impor Klip: Kemampuan menggunakan salah satu channel kamera cadangan untuk mengimpor klip ke dalam produksi. - Multiview Replay: Penambahan opsi tata letak multiview khusus untuk produksi 10, 12, dan 16 kamera. - API Replay: Akses yang lebih luas melalui API untuk melihat event dan informasi multiview.
Output dan Performa:
- 8 Output: Peningkatan jumlah output hingga 8 channel (termasuk dukungan external output).
Input dan Desain:
- Browser Input: Pembaruan ke versi Chrome yang lebih baru untuk mendukung fitur CSS terbaru. - Presenter Mode: Mode pratinjau baru untuk slideshow agar operator bisa melihat slide sebelum ditayangkan. - Dukungan PowerPoint: Fitur bawaan untuk menjalankan file PowerPoint tanpa perlu menginstal Microsoft Office. - V-Mix GT: Masking kualitas tinggi (termasuk inverted masks), alat eyedropper untuk warna, dan kemampuan menyalin properti antar elemen. - Overlay Designer: Desainer baru untuk konfigurasi overlay dengan dukungan efek dan bentuk (seperti lingkaran atau kotak dengan sudut membulat).
Audio dan Streaming:
- Audio Effects: Penambahan peredam bising (noise suppression) melalui RN Noise dan efek RTX audio (denoising dan dereverb). - SRT Streaming: Dukungan streaming langsung ke SRT melalui tombol Stream dengan pengaturan FFmpeg.
Produk Baru:
- V-Mix IO: Software gratis (Windows/Linux) untuk mengonversi capture card (seperti DeckLink) menjadi sumber OMT guna menambah jumlah input kamera dengan biaya lebih terjangkau.
Joined: 9/16/2026(UTC) Posts: 2   Location: Lubelskie
Originally Posted by: ryxyz  - Maximum number of replay cameras to 16 - Can import clips to a replay channel - 10, 12, 16 channel replay multiviews - More replay APIs - Increased outputs to 8 - Updated Chrome Browser version - Slideshow input presenter mode - Built-in powerpoint support - Mousewheel scroll for lists - GT Titles: Inverted mask support, copy properties between elements, change multiple text fields at once, eye dropper tool - More list information (e.g. total list duration) - More list shortcuts/APIs - Data source formatting support for numbers, dates - Tally pass-through for mix inputs - Message support for production clocks - More multiview layouts/options - New overlay designer w/ effects support (shapes, borders, rounded borders) - SRT updated to latest version - Support SRT as stream output - Decklink 8-bit to 10-bit convert - Audio effects (RNNoise, RTX Audio Effects) - New free 'vMix iO' software for Windows, Linux to convert SDI to OMT v29.0.0.49 1. Please add snapping to grid and "+" and "-" buttons for image scaling (the slider alone isn't very precise). 2. It copies only the scaling but not the edge cropping—why? (I want to copy all settings, not just the scaling.) 3. Change name "Crop X1, ...etc" to "Left, top, right, bottom" 4. PAN X, PAN Y, Rotate: Z for CROP or like a RESOLUME MASK SCREEN
What is your vMix version? Using latest verion 29.0.0.49:
1. Please add snapping to grid and "+" and "-" buttons for image scaling (the slider alone isn't very precise). You can use mousewheel to be very precise, like + and -
2. It copies only the scaling but not the edge cropping—why? (I want to copy all settings, not just the scaling.) vMix allow copying all settings.
Originally Posted by: ryxyz  1. Please add snapping to grid and "+" and "-" buttons for image scaling (the slider alone isn't very precise).
This doesn't exactly solve your issue, but you can use your mouse scrollwheel while hovering over the zoom/pan/crop settings to fine-tune your values.
Anyone know about release/beta? Seems oddly late.
Originally Posted by: sg93  Anyone know about release/beta? Seems oddly late. Better late and proper with fewer hiccups to discover by us ;-) If they keep adding the feature requests first it might be never LOL And yes I am waiting too (im)patiently
