Joined: 2/4/2019(UTC) Posts: 3  Location: Adelaide Thanks: 2 times
An option to iterate through the rows from a data source so you only need to select the start column/row for each value and then it will generate all the rows of graphics. This would save having to link a hundred cells in a table of data.
Originally Posted by: schrojo  An option to iterate through the rows from a data source so you only need to select the start column/row for each value and then it will generate all the rows of graphics. This would save having to link a hundred cells in a table of data. The question sounds confusing but i believe you are trying to connect the various data of a row to the appropriate title locations. if that is the case one can automatically bind/link them to the title by using the same name for the data columns headings as the title item names! To iterate through the rows ,select a row and use the next row function as short cut or within a script If neither is what you are looking for please rephrase your question (distinction rows versus columns!)
