schrojo
#1 Posted : Sunday, September 6, 2026 11:39:23 AM(UTC)
schrojo
An option to iterate through the rows from a data source so you only need to select the start column/row for each value and then it will generate all the rows of graphics. This would save having to link a hundred cells in a table of data.
#2 Posted : Sunday, September 6, 2026 6:25:47 PM(UTC)
The question sounds confusing but i believe you are trying to connect the various data of a row to the appropriate title locations. if that is the case one can automatically bind/link them to the title by using the same name for the data columns headings as the title item names!
To iterate through the rows ,select a row and use the next row function as short cut or within a script
If neither is what you are looking for please rephrase your question (distinction rows versus columns!)
