leninhn
#1 Posted : Friday, August 14, 2026 10:30:23 AM(UTC)
leninhn
Honduras
Hello, I have a question: currently, when the SRT in CRB goes black, the bitrate doesn't remain constant, even if you configure it to 5 Mbps in CRB. When the video is static or the screen goes black, the bitrate doesn't stay at 5000 kbps and drops to 425 kbps. Is there a solution?
jet
#2 Posted : Tuesday, August 18, 2026 9:09:28 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Did the recent vMix SRT update fix the issue?
vMix v29.0.0.49: "Updated SRT version to 1.5.6"
leninhn
#3 Posted : Wednesday, August 19, 2026 1:33:53 AM(UTC)
leninhn
Honduras
No, there's no solution. The new update doesn't improve SRT at all; in short, it's more of the same. I just wrote this in another post; let's see what the developers say.
**What is the point of improving SRT if vMix still cannot provide a true strict CBR stream?**
I have been testing SRT output from vMix and I think there is an important issue that still needs attention: **strict Constant Bitrate (CBR).**
For example, I configured my stream at approximately **6000 kbps video + 128 kbps audio**.
When the video contains normal movement, measuring the actual SRT transport gives me around **817 KiB/s (~6.7 Mbps)**, which is what I would expect.
However, when the source becomes a static image, the same SRT output drops to approximately **38.2 KiB/s (~0.31 Mbps)**.
That is a reduction of more than 95%.
So even though a fixed bitrate is configured in vMix, the resulting stream is clearly not maintaining that bitrate when the picture has little or no movement.
This matters in professional broadcast/IPTV environments. Some downstream equipment and distribution systems expect a stable transport bitrate. A static image should not cause a 6 Mbps stream to suddenly collapse to a few hundred kbps.
My question to the vMix developers is:
**Why doesn't vMix provide an option for true strict CBR / constant transport bitrate when using SRT?**
SRT itself keeps receiving improvements and updates, which is welcome, but for broadcast contribution I think having the option to maintain a genuinely constant output bitrate is just as important.
It would be very useful to have something equivalent to a strict CBR mode where, if the encoder doesn't need the entire configured bitrate for the video, the transport stream is padded appropriately so that the final output remains constant.
For IPTV and broadcast distribution, this would make SRT output from vMix much more predictable and reliable.
#4 Posted : Wednesday, August 19, 2026 2:35:56 AM(UTC)
CBR in SRT definitely does work in vMix and I just tested to confirm this is the case, sending a static image at 10Mbps.
I would suggest you contact vMix Support if you still believe this is not working...
https://www.vmix.com/contact-us.aspx
leninhn
#5 Posted : Wednesday, August 19, 2026 4:03:21 AM(UTC)
leninhn
Honduras
Thanks for running the test. I've continued testing and found an important detail.
You are correct that **if I load a static image directly into vMix, CBR is maintained correctly**.
The problem occurs while playing a video file, such as a movie, when the content reaches a completely black screen, a long fade to black, or end credits over a black background.
During normal video content, the stream stays around the configured bitrate. However, during these very dark or low-complexity sections, the bitrate can drop dramatically. As soon as normal content returns, the bitrate goes back up.
I've also tested Hardware Encoder, Software Encoder, and Low Power Hardware Encoder, with the same behavior.
So I believe testing only with a static image does not reproduce the specific issue I'm seeing. It would be interesting to test with a video containing several seconds of black screen or credits over a black background and check whether the SRT output continues to maintain the full 10 Mbps.
I will also open a support ticket with vMix including these details.
Thanks again for testing this.
thanks 1 user thanked leninhn for this useful post.
jet on 8/19/2026(UTC)
Peter1000
#6 Posted : Friday, August 21, 2026 6:01:45 AM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
I can confirm that CBR in vMix does not appear to be true CBR.
We sometimes send content to Eurovision Services, which requires SRT streams at 10 Mbps, H.264, CBR, and AES-256 encryption.
With vMix, EBU consistently gets a CBR alarm, and this seems to be exactly why: if the video contains static scenes or even an occasional black frame or black screen, the bitrate drops significantly.
With these decoders, significant bitrate drops can cause audio dropouts.
The decoders in the Eurovision Services control room have a checkbox labeled “Allow VBR.” Enabling this suppresses the alarm, and the audio dropouts no longer occur. However, this is essentially treating the symptom rather than addressing the underlying issue.
We have observed this with vMix versions 28.x and 29.x. We have not yet tested the latest versions, which use a newer SRT package.
Incidentally, the same behavior also occurs with our Kiloview encoders, E1 and E3. Our Haivision and Matrox encoders, on the other hand, provide rock-solid CBR — but they also cost several times as much.
thanks 1 user thanked Peter1000 for this useful post.
jet on 8/21/2026(UTC)
#7 Posted : Friday, August 21, 2026 5:09:31 PM(UTC)
We have confirmed via vMix Support directly with the user that CBR SRT was indeed working correctly.
This was confirmed by checking the actual bitrate sent via SRT statistics.
(It is not accurate at all to say SRT CBR in vMix is not "true CBR")
Note that SRT CBR in vMix works by filling in extra packets in the underlying transport stream (MPEG-TS), which is how CBR works for DVB MPEG-TS streams for broadcast television for example.
However there is also a CBR method where the extra packets are added to the H264 bitstream directly.
Both achieve the exact same result in reality, but some decoders may only be checking for one particular CBR method and ignoring the other, leading to discrepancies and alerts in those cases.
However in practice, this does not effect the actual performance of the stream.
