SRT
SRT No constant biltrate
Joined: 10/29/2025(UTC) Posts: 5   Location: Cortés Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello, I have a question: currently, when the SRT in CRB goes black, the bitrate doesn't remain constant, even if you configure it to 5 Mbps in CRB. When the video is static or the screen goes black, the bitrate doesn't stay at 5000 kbps and drops to 425 kbps. Is there a solution?
Joined: 11/14/2012(UTC) Posts: 359  Location: Finland Thanks: 227 times Was thanked: 24 time(s) in 22 post(s)
Did the recent vMix SRT update fix the issue?
vMix v29.0.0.49: "Updated SRT version to 1.5.6"
No, there's no solution. The new update doesn't improve SRT at all; in short, it's more of the same. I just wrote this in another post; let's see what the developers say.
**What is the point of improving SRT if vMix still cannot provide a true strict CBR stream?**
I have been testing SRT output from vMix and I think there is an important issue that still needs attention: **strict Constant Bitrate (CBR).**
For example, I configured my stream at approximately **6000 kbps video + 128 kbps audio**.
When the video contains normal movement, measuring the actual SRT transport gives me around **817 KiB/s (~6.7 Mbps)**, which is what I would expect.
However, when the source becomes a static image, the same SRT output drops to approximately **38.2 KiB/s (~0.31 Mbps)**.
That is a reduction of more than 95%.
So even though a fixed bitrate is configured in vMix, the resulting stream is clearly not maintaining that bitrate when the picture has little or no movement.
This matters in professional broadcast/IPTV environments. Some downstream equipment and distribution systems expect a stable transport bitrate. A static image should not cause a 6 Mbps stream to suddenly collapse to a few hundred kbps.
My question to the vMix developers is:
**Why doesn't vMix provide an option for true strict CBR / constant transport bitrate when using SRT?**
SRT itself keeps receiving improvements and updates, which is welcome, but for broadcast contribution I think having the option to maintain a genuinely constant output bitrate is just as important.
It would be very useful to have something equivalent to a strict CBR mode where, if the encoder doesn't need the entire configured bitrate for the video, the transport stream is padded appropriately so that the final output remains constant.
For IPTV and broadcast distribution, this would make SRT output from vMix much more predictable and reliable.
Joined: 1/13/2010(UTC) Posts: 5,322  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
CBR in SRT definitely does work in vMix and I just tested to confirm this is the case, sending a static image at 10Mbps. I would suggest you contact vMix Support if you still believe this is not working... https://www.vmix.com/contact-us.aspx
Thanks for confirming this.
That's actually very useful information, because what you describe is exactly the behavior I'm expecting from vMix, but unfortunately I'm not seeing it on my system.
I have CBR enabled on the SRT output. With approximately 6000 kbps video + 128 kbps audio configured, I measured the actual SRT traffic directly.
With normal moving video:
**~817 KiB/s (~6.7 Mbps)**
With a completely static image:
**~38.2 KiB/s (~0.31 Mbps)**
So the transport bitrate is clearly dropping when the image becomes static instead of being padded to maintain the configured rate.
I have also already tested different encoder configurations, including hardware encoding, software encoding and Low Power hardware encoding, with the same issue.
Since you have confirmed that your test maintains 10 Mbps even with a static image, there must be a difference somewhere in our configurations or systems.
Before contacting support, could you please tell me what encoder you used for your 10 Mbps test (hardware/software), codec, and how you measured the resulting SRT bitrate?
That would allow me to reproduce your test as closely as possible.
Thanks.
SRT
