alefello
#1 Posted : Tuesday, August 18, 2026 12:10:10 AM(UTC)
alefello
Italy
Hello everybody
I'm looking some refurbished workstations to replace the previous one that died due to a storm.
I've 5 FullHD Panasonic PTZ cameras that are H.264 inputs currently but I'm planning to move to NDI, 2 SDI inputs on a Blackmagic pci-express card, 1 broadcast audio input USB card and I use some videos to play as opening and closing of the streaming. I stream to 2 different destinations with different qualities. The workflow is simply a streaming that I open/close with a video and switch the cameras.
What minimum configuration do you recommend? I'm looking for refurbished workstations so keep in mind that maybe I won't find 5000 series NVIDIA cards but older series, same with the CPU.
Thank you
Kayo33
#2 Posted : Sunday, August 30, 2026 11:08:22 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: alefello Go to Quoted Post
Hello everybody
Thank you
For your needs, a 2nd hand desktop PC is sufficient
If no recording is required, a Z390 or Z490 system will do the job :
MB = ASRock Z390 Taichi or MSI MEG Z390 Ace
CPU = i9-9900K
DDR4 = 32 GB DDR4-2666
SSD = M.2 pcie 3.0 x4 for windows/vmix
GPU = RTX 3060 12 Gb or higher
NDI + STREAM = Intel X550-T2 pcie card
SDI = Blackmagic decklink duo 2
MB = Asus Rog Strix Z490 A-Gaming or Asus Rog Strix Z490 H-Gaming
CPU = i9-10900K
DDR4 = 32 GB DDR4-2933
if use rec, Z590 system :
MB = Asus Rog Strix Z590 A-Gaming or Asus Prime Z590-A
CPU = i7-11700K or i9-11900K
DDR4 = 32 GB DDR4-3200
SSD = M.2 pcie 3.0 x4 for windows/vmix (in M.2_3 port)
GPU = RTX 3060 12 Gb or higher (RTX 4070 Ti 12 Gb is best choice because it has two NVENC encoders)
SSD = M.2 pcie 4.0 x4 for rec (in M.2_1 port/ Samsung 990 Pro)
NDI + STREAM = Intel E610-XT2 pcie card
examples :
PC
https://www.subito.it/in...ing-trento-651041703.htm
GPU
https://www.subito.it/in...6x-bolzano-658794319.htm
LAN PCIE CARD
https://www.ebay.it/sch/...0&_trksid=m570.l1313
alefello
#3 Posted : Tuesday, September 1, 2026 6:56:11 PM(UTC)
alefello
Italy
Originally Posted by: Kayo33 Go to Quoted Post
For your needs, a desktop PC is sufficient
CPU = i9-9900K
NDI + STREAM = Intel X550-T2 pcie x4 card
SDI = Blackmagic pcie x4 card
CPU = i9-10900K
examples :
PC
GPU
LAN PCIE CARD
Thank you for the details and the kindness of linking me some used hardware.
Unfortunately I really need to go with an used workstation cause of the budget and refurbished workstations are really really cheap for the hardware they have. Is it really necessary for my setup an Nvidia RTX3060 or RTX4070Ti? A part from the NVENC encoders (which I can replace with CPU encoding if I get some really good deal on a workstation maybe with a Threadripper 32C/64T) what is the GPU used for in vMix?
Thank you
vmixgreg
#4 Posted : Tuesday, September 1, 2026 8:41:15 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Please note, next to the CPU, the GPU is the single most important component in your computer for vMix:
vMIx Greg
Kayo33
#5 Posted : Wednesday, September 2, 2026 2:49:08 AM(UTC)
Kayo33
Thank you
The GPU handles everything: scaling and multiview display, compositing/chroma key, effects and transitions, video playback and decoding, input/output buffer management, and streaming encoding.
It handles anything that can offload your CPU, allowing it to focus on other tasks—like NDI High Bandwidth, for example.
If your Panasonic cameras only support NDI HX, you will need a dedicated GPU.
An AMD Ryzen Threadripper (32 cores/64 threads) is complete overkill for your use case.
That said, if you have the budget, having more power than strictly necessary never hurts.
However, a GPU is essential in your case, GeForce RTX card is sufficient.
