adambou
#1 Posted : Sunday, August 9, 2026 10:38:34 PM(UTC)
adambou
Would love to be able to zoom in during a replay especially when live footage wasn't zoomed in enough. I can set a shortcut to set the zoom via position. As i will be zooming during the replay, i want a soft merging type zoom not and immediate cut to zoom that looks so jumpy.
any ideas?
yahoo_1999
#2 Posted : Monday, August 10, 2026 12:59:00 AM(UTC)
yahoo_1999
Poland
If you're fine with zoom presets instead of variable live control you could do with virtual inputs / blank inputs with replay as a layer and zoomed in and just merge transition between them.
#3 Posted : Monday, August 10, 2026 4:17:12 AM(UTC)
any ideas?
Can easily create a soft zoom with a short cut "SetZoom" on the replay input with an additive value like +=0.01 (Very small step example). keep the shortcut key pressed for a smooth continuous zoom
