Instant Replay
How to zoom in while watching replay
Joined: 9/5/2020(UTC) Posts: 38  Location: brisbane Thanks: 2 times
Would love to be able to zoom in during a replay especially when live footage wasn't zoomed in enough. I can set a shortcut to set the zoom via position. As i will be zooming during the replay, i want a soft merging type zoom not and immediate cut to zoom that looks so jumpy.
any ideas?
Joined: 7/30/2026(UTC) Posts: 2  Location: Warsaw Thanks: 1 times
If you're fine with zoom presets instead of variable live control you could do with virtual inputs / blank inputs with replay as a layer and zoomed in and just merge transition between them.
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: adambou  Would love to be able to zoom in during a replay especially when live footage wasn't zoomed in enough. I can set a shortcut to set the zoom via position. As i will be zooming during the replay, i want a soft merging type zoom not and immediate cut to zoom that looks so jumpy.
any ideas? Can easily create a soft zoom with a short cut "SetZoom" on the replay input with an additive value like +=0.01 (Very small step example). keep the shortcut key pressed for a smooth continuous zoom
Instant Replay
