byaron22
#1 Posted : Thursday, July 16, 2026 3:25:22 AM(UTC)
byaron22
We are having issues with instant replay having a lag/stutter/pause for roughly a half second every 3 or so seconds for every replay. We have tried just about everything to try and figure this out. We have updated BIOS, Windows Update, driver updates, vMix update, etc. We have tried recording to internal and external SSD, changed replay quality, tried CPU and GPU for performance, changed different graphic setting through NVIDIA control panel and Windows Graphics settings, made sure framerates matches for project, replay and cameras and much more for troubleshooting. We cannot figure out why we are getting this stutter. We use a Panasonic CX350 connected via SDI to a BlackMagic Design ATEM SDI Pro ISO that is connected via USB C to our computer. The live video looks great and doesn't have a stutter ONLY our replays have this stutter.
Kayo33
#2 Posted : Thursday, July 16, 2026 3:56:55 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
PC Desktop or Laptop ? PC reference and PC specifications?
byaron22
#3 Posted : Thursday, July 16, 2026 4:34:08 AM(UTC)
byaron22
It's a laptop.
CPU: AMD Ryzen 7 6800H
Memory: 16GB DDR5 4800MHz
GPU: Nvidia GeForce RTX 3050
Hard Drive: 512GB PCIe SSD
External Drive: Samsung 870 EVO SSD
Kayo33
#4 Posted : Thursday, July 16, 2026 4:50:18 AM(UTC)
Kayo33
Use an SDI or HDMI-to-USB capture card
and connect output SDI ATEM or CX350 directly to the PC.
For replays, it is best to have a dedicated internal M.2 SSD;
check if you can add an M.2 SSD to the laptop.
#5 Posted : Friday, July 17, 2026 9:10:15 PM(UTC)
@ byaron22
You'd be hard pressed to find a laptop that meets the system requirements for vMix Instant Replay:
- https://www.vmix.com/hel.../SystemRequirements.html
byaron22
#6 Posted : Saturday, July 25, 2026 12:36:00 AM(UTC)
byaron22
Originally Posted by: IceStream Go to Quoted Post
@ byaron22
This laptop actually works great for it.
byaron22
#7 Posted : Saturday, July 25, 2026 12:39:34 AM(UTC)
byaron22
I ended up finding a resolution to this issue. I set output 2 in vMix to the BlackMagic ATEM and then under the Instant Replay settings, set the camera to Output 2. After doing this, the replays no longer have the stutter in it. We also have another streaming setup that uses and Elgato Capture Card that had the same issue and doing this also fix it. Not sure if something in the latest vMix update, or a Windows update caused this issue to present itself, but never had issues until recently.
