Instant Replay
Instant Replay Has A Stutter Every 3 Seconds
We are having issues with instant replay having a lag/stutter/pause for roughly a half second every 3 or so seconds for every replay. We have tried just about everything to try and figure this out. We have updated BIOS, Windows Update, driver updates, vMix update, etc. We have tried recording to internal and external SSD, changed replay quality, tried CPU and GPU for performance, changed different graphic setting through NVIDIA control panel and Windows Graphics settings, made sure framerates matches for project, replay and cameras and much more for troubleshooting. We cannot figure out why we are getting this stutter. We use a Panasonic CX350 connected via SDI to a BlackMagic Design ATEM SDI Pro ISO that is connected via USB C to our computer. The live video looks great and doesn't have a stutter ONLY our replays have this stutter.
Joined: 10/20/2023(UTC) Posts: 163  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
PC Desktop or Laptop ? PC reference and PC specifications?
It's a laptop.
CPU: AMD Ryzen 7 6800H Memory: 16GB DDR5 4800MHz GPU: Nvidia GeForce RTX 3050 Hard Drive: 512GB PCIe SSD External Drive: Samsung 870 EVO SSD
Use an SDI or HDMI-to-USB capture card and connect output SDI ATEM or CX350 directly to the PC. For replays, it is best to have a dedicated internal M.2 SSD; check if you can add an M.2 SSD to the laptop.
Originally Posted by: IceStream  This laptop actually works great for it.
I ended up finding a resolution to this issue. I set output 2 in vMix to the BlackMagic ATEM and then under the Instant Replay settings, set the camera to Output 2. After doing this, the replays no longer have the stutter in it. We also have another streaming setup that uses and Elgato Capture Card that had the same issue and doing this also fix it. Not sure if something in the latest vMix update, or a Windows update caused this issue to present itself, but never had issues until recently.
Instant Replay
