NAC New Haven
#1 Posted : Sunday, June 28, 2026 6:08:33 AM(UTC)
NAC New Haven
I recently updated Windows 11 and vMix on the same day - June 7, 2026. Since then, whenever I open an existing file, the inputs show up on the screen but are blank. I went through different settings in Windows and vMix with no change. I stumbled upon the audio output in settings and found it set to speakers. I changed it to headphones (which we use), which matches the Windows setting. Clicked OK and vMix restarted and everything was normal. Next time it did the same, and I changed the output to Windows default, and vMix worked again.
It seems there is a disconnect in the software. I can change back and forth between headphones and the default and vMix works perfectly after it restarts.
Do you know of any fix for this issue?
Kayo33
#2 Posted : Sunday, June 28, 2026 7:20:10 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
This looks more like a Windows issue.
Reinstall Windows 11 and install all updates,
then reinstall vMix and the capture card drivers.
AlthalusAvan
#3 Posted : Friday, July 10, 2026 3:16:36 AM(UTC)
AlthalusAvan
I'm having the same issue - latest Win11 build, all drivers on current latest (Nvidia Studio drivers).
When I open a show file, everything displays normally for around 5-10 seconds and then every input goes blank. Audio works as normal.
Triggering any restart (changing an audio output or a video setting) makes everything work fine.
Very weird issue - I can't say exactly when it started as I haven't used vMix on this machine in 2-3 months.
thanks 1 user thanked AlthalusAvan for this useful post.
RUN TV on 7/20/2026(UTC)
#4 Posted : Friday, July 10, 2026 11:15:37 AM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
This is due to a corrupt install, usually due to other programs blocking vMix from updating critical files.
Make sure to pay attention to any messages during install and if there are any, to restart the computer, close any programs (including background programs like Zoom) and install again.
AlthalusAvan
#5 Posted : Tuesday, July 14, 2026 7:44:57 PM(UTC)
AlthalusAvan
Yep, this worked. When I was removing files some of them couldn't be deleted because of one of Slack/Discord/Teams. Closed them all, removed all files, installed fresh, and we're good to go.
