gabi
#1 Posted : Friday, June 19, 2026 7:56:03 PM(UTC)
gabi
Romania
Faulting application name: vMix64.exe, version: 29.0.0.48, time stamp: 0x6a1e84ca
Faulting module name: Processing.NDI.Lib.dll, version: 6.3.2.0, time stamp: 0x69deb4a0
Exception code: 0xc0000005
Fault offset: 0x0000000000233ce6
Faulting process id: 0x1C6C
Faulting application start time: 0x1DCFF2C90BE6859
Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe
Faulting module path: C:\Program Files (x86)\vMix\ndi\x64\Processing.NDI.Lib.dll
Report Id: 0e68ca62-6c9e-4626-840b-975ab85edac3
Faulting package full name:
Faulting package-relative application ID:
Log Name: Application
Source: Application Error
Event ID: 1000
Level: Error
User: USER\USER
OpCode: Info
Logged: 19/06/2026 08:29:28
Task Category: Application Crashing Events
Keywords:
Computer: USER
Can someone help me with this error?
jip
#2 Posted: : Tuesday, June 23, 2026 12:10:27 AM(UTC)
jip
Estonia
Have you tested how a single NDI input with FEIM (faultly encoder isolation) enabled work? Do you have crashes or freezing NDI?
What is you CPU? Intel 13th/14th generation processors are known to cause self-degradation prior to a microcode update. 0xc0000005 errors may be one symptom for that problem. NDI decoding is CPU-intensive and decoder could run more or less by random on a degraded CPU core, leading to crash.
kross
#3 Posted : Tuesday, June 30, 2026 5:28:50 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
One way to confirm if you do have the Intel bug is to try to reproduce the crash outside of vMix, using tools like y-cruncher or prime95. These are CPU stress test programs, and can usually identify a faulty CPU. Sometimes it takes an hour or two for it to show up, so let it run for a while.
