Faulting application name: vMix64.exe, version: 29.0.0.48, time stamp: 0x6a1e84ca Faulting module name: Processing.NDI.Lib.dll, version: 6.3.2.0, time stamp: 0x69deb4a0 Exception code: 0xc0000005 Fault offset: 0x0000000000233ce6 Faulting process id: 0x1C6C Faulting application start time: 0x1DCFF2C90BE6859 Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe Faulting module path: C:\Program Files (x86)\vMix\ndi\x64\Processing.NDI.Lib.dll Report Id: 0e68ca62-6c9e-4626-840b-975ab85edac3 Faulting package full name: Faulting package-relative application ID:
Log Name: Application Source: Application Error Event ID: 1000 Level: Error User: USER\USER OpCode: Info Logged: 19/06/2026 08:29:28 Task Category: Application Crashing Events Keywords: Computer: USER
Can someone help me with this error?
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: gabi  Faulting application name: vMix64.exe, version: 29.0.0.48, time stamp: 0x6a1e84ca Faulting module name: Processing.NDI.Lib.dll, version: 6.3.2.0, time stamp: 0x69deb4a0 Exception code: 0xc0000005
Have you tested how a single NDI input with FEIM (faultly encoder isolation) enabled work? Do you have crashes or freezing NDI? What is you CPU? Intel 13th/14th generation processors are known to cause self-degradation prior to a microcode update. 0xc0000005 errors may be one symptom for that problem. NDI decoding is CPU-intensive and decoder could run more or less by random on a degraded CPU core, leading to crash.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
One way to confirm if you do have the Intel bug is to try to reproduce the crash outside of vMix, using tools like y-cruncher or prime95. These are CPU stress test programs, and can usually identify a faulty CPU. Sometimes it takes an hour or two for it to show up, so let it run for a while.
