Matts887
#1 Posted : Tuesday, June 2, 2026 10:38:07 AM(UTC)
Matts887
I'm troubleshooting an NDI issue and have isolated it as much as I can before posting.
System
vMix 29.0.0.47 (Trial)
Lenovo Legion 5i Gen 10
Intel Core Ultra 7 255HX
NVIDIA RTX 5070 Laptop GPU
32GB RAM
Windows 11 Pro
Internal NVMe SSD
Netgear GS305EP Smart Managed PoE Switch
Camera
PTZOptics Studio 4K
Latest firmware installed
NDI enabled
Tested both Full NDI and NDI HX3
Symptoms
When using the PTZOptics camera as an NDI source in vMix, I consistently receive Source Drops, Render Drops, and Sync Issues.
Example results:
1080p30 NDI (RTX 5070)
79 Source Drops
32 Render Drops
20 Sync Issues
4K30 NDI
Even higher drop counts than 1080p
What I've Tested
GPU
Tested on NVIDIA RTX 5070
Tested on Intel integrated graphics
Issue occurs on both
Recording
Tested with recording enabled
Tested with recording disabled
Issue occurs in both scenarios
HDMI Comparison
Using the same PTZOptics camera via HDMI into a Magewell capture device:
1080p29.97 HDMI
0 Source Drops
0 Render Drops
0 Sync Issues
This appears completely stable.
NDI Studio Monitor
Viewed the PTZOptics NDI stream in NDI Studio Monitor for several minutes.
No visible stutters
No freezes
No reconnects
Stream appears stable
Network Adapter Tuning
Disabled:
Energy Efficient Ethernet
Green Ethernet
Power Saving features
Interrupt Moderation
This reduced Render Drops significantly but did not eliminate the problem.
Network
Ethernet link speed confirmed at 1.0 Gbps
PTZOptics connected through Netgear GS305EP switch
No other significant traffic on the network
Project Settings
Tested 1080p30
Tested 2160p30
Camera and project frame rates matched
Performance
CPU usage remains very low
GPU usage remains low
Render times generally between 2ms and 9ms
Question
Since:
HDMI from the same camera is perfect,
NDI Studio Monitor appears stable,
The issue occurs on both Intel and NVIDIA GPUs,
The issue occurs at both 1080p and 4K,
I'm trying to determine whether this points to:
A PTZOptics NDI implementation issue
NDI runtime/configuration issue
Network adapter/driver issue
Something specific to vMix's handling of this NDI source
Has anyone experienced similar behavior with PTZOptics Studio 4K cameras and NDI in vMix?
Any suggestions for additional diagnostics would be greatly appreciated.
Kayo33
#2 Posted : Thursday, June 18, 2026 4:16:34 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Maybe :
PTZ Optics firmware
LAN driver reinstallation
LAN settings to adjust in BIOS
see also in Lenovo Vantage
BIOS update
VMix settings
jet
#3 Posted : Friday, June 26, 2026 3:51:13 PM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Run LatencyMon in the background and see what results it gives.
https://resplendence.com/latencymon
Maximus
#4 Posted : Sunday, June 28, 2026 8:26:47 AM(UTC)
Maximus
I have had that problem, and it appears to be a Lenovo problem. The same network and connections on multiple different computers were all good, only the Lenovo gave me aproblems. And it was a well speced laptop with a 4080 graphics card. I wiped an reinstalled everthing, tested for months, checked multiple forums for suggestions including parking cores, all to no avail. So i have abandoned that laptop for any production and will not invest in other Lenovo's laptops. Your mileage may vary.
Maxi
Kayo33
#5 Posted : Sunday, June 28, 2026 7:25:31 PM(UTC)
Kayo33
install on thunderbolt 4 port
tb4 pcie enclosure + intel x550-t2 pcie card
