28 Pages«<262728
#541 Posted : Wednesday, March 11, 2026 2:23:09 AM(UTC)
Here is a basic script to rename the (multicorder) video files according their actual creation time
issue addressed here
https://forums.vmix.com/posts/t3...recording-and-file-names
and here
https://forums.vmix.com/posts/t3...ame-for-split-recordings
Code:
    Try
        Dim filepath as string = "d:\multicordertest\"
        Dim filepathnew as string = "d:\multicordertest\renamed\"
        ' assuming multicorderfiles are saved as mp4 else change extention
        Dim dirs As String() = Directory.GetFiles(filepath , "*.mp4")
        Dim vidfile As String
        For Each vidfile In dirs
            Console.WriteLine(vidfile )
            ' get creation date of video
            Dim fileCreatedDate As DateTime = File.GetCreationTime(vidfile )
            ' create new fileame like dd-mm-yy hh-mm-ss.mp4
            Dim CreatedDate as String = fileCreatedDate .Day & "-" & fileCreatedDate .Month & "-" & fileCreatedDate .Year
            Dim CreatedTime as String = fileCreatedDate .Hour & "-" & fileCreatedDate .Minute & "-" & fileCreatedDate .Second
            Dim newfile as string = CreatedDate + " " + CreatedTime + ".mp4"
            Console.WriteLine(filepathnew  &  newfile)
            ' rename/move file to new folder
            System.IO.File.Move(vidfile, filepathnew & newfile)
        Next
    Catch e As Exception
        Console.WriteLine("The process failed:")
    End Try
jet
#542 Posted : Thursday, June 11, 2026 2:42:14 AM(UTC)
jet
Was thanked: 26 time(s) in 24 post(s)
Is it possible to read the current position of the T-BAR and get the current position (0-255)?
TL68
#543 Posted : Monday, July 6, 2026 4:26:41 PM(UTC)
TL68
Sweden
Script (created with AI) which toggles input in a layer ("layerNumber") on an input ("target input") between defined inputs ("source inputs"). It works with input numbers or input names.
Code:
' SETTINGS
' Change to your actual input numbers or names
Dim targetInput As String = "1"
Dim layerNumber As Integer = 1
Dim sourceInputs() As String = {"2", "3", "4"}
Dim xml As String = API.XML()
Dim x As New System.Xml.XmlDocument
x.LoadXml(xml)
' The correct XML path for vMix Dynamic Values is //dynamic/value1
Dim currentIndexNode As System.Xml.XmlNode = x.SelectSingleNode("//dynamic/value1")
Dim currentIndexStr As String = ""
If currentIndexNode IsNot Nothing Then
    currentIndexStr = currentIndexNode.InnerText
End If
Dim currentIndex As Integer = 0
' Attempt to convert the saved value to an integer
If Integer.TryParse(currentIndexStr, currentIndex) Then
    ' Move to the next input in the list
    currentIndex = currentIndex + 1
Else
    ' If the value is empty (e.g., the very first time the script runs)
    currentIndex = 0
End If
' If we have reached the end of the list, start over from zero
If currentIndex >= sourceInputs.Length Then
    currentIndex = 0
End If
' Get the name/number of the next input from the list
Dim nextInput As String = sourceInputs(currentIndex)
' Print info in the vMix Scripting log for troubleshooting
Console.WriteLine("Found saved index: " & currentIndexStr)
Console.WriteLine("Changing to index: " & currentIndex & " (Which is Input: " & nextInput & ")")
' Build the SetLayer command and send it to vMix
Dim layerValue As String = layerNumber.ToString() & "," & nextInput
API.Function("SetLayer", Input:=targetInput, Value:=layerValue)
' Save the new index so vMix remembers it for the NEXT time the script is executed
API.Function("SetDynamicValue1", Value:=currentIndex.ToString())
28 Pages«<262728
