Feature Requests
The ability to add exported clips or imported videos into vMix Replay
Joined: 1/5/2013(UTC) Posts: 36   Location: Jamaica Thanks: 102 times Was thanked: 3 time(s) in 3 post(s)
Good day, all.
I have been using vMix Replay to do sports like cricket, soccer, basketball and other sports at a high level at times. The biggest issue is that I can't add clips from old recorded sessions or from clips exported from a previous session, either. There are times when I would want to import even the video elements into the session, but I would have to record it via an Output and map it into the replay session, which is time-consuming. Could we add a feature or a way for us to add these clips into the sessions better, or even the ability to link sessions together for a better workflow?
I look forward to this feature to be into a next vMix to come.
Cheers, Adrian
 1 user thanked Adriankey4 for this useful post.
Cheers, Adrian Please explain as seem to be missing the point as to why precisely. Based on how a session data is kept i doubt a complete rewrite of the IR filing system is going to happen soon. The nice thing though one can "pause" a session and continue later with the same one say multiple games in one session. One can recall a previous session by "changing" the IR input (folder) and continue there also (but check the camera inputs used). As for exported clips, why not just put them in a list to play back? the ability to link sessions together i agree on (maybe but again why exactly in practise)
Joined: 9/25/2019(UTC) Posts: 18  Location: Edenvale Was thanked: 1 time(s) in 1 post(s)
Joined: 4/3/2022(UTC) Posts: 38  Thanks: 7 times Was thanked: 21 time(s) in 9 post(s)
Cheers, Adrian Please explain as seem to be missing the point as to why precisely. Based on how a session data is kept i doubt a complete rewrite of the IR filing system is going to happen soon. The nice thing though one can "pause" a session and continue later with the same one say multiple games in one session. One can recall a previous session by "changing" the IR input (folder) and continue there also (but check the camera inputs used). As for exported clips, why not just put them in a list to play back? the ability to link sessions together i agree on (maybe but again why exactly in practise) To answer your question: there are many use cases for weaving ingested assets together with replay content in a playlist context. And, it's nice to have one UI for all of the countdowns and assets when possible. The only way to gracefully do this, currently, is to record all of those assets to the replay drive (and clip them all out, and label them). This is time consuming and also must be re-done every session. Pretty much EVERY adopted replay solution in sports supports this, from EVS and Dreamcatcher all the way down to the more budget 3Play (even the older ones), because replay and playback are generally the same role
Feature Requests
