Adriankey4
#1 Posted : Tuesday, February 24, 2026 4:31:41 AM(UTC)
Adriankey4
Jamaica
Good day, all.
I have been using vMix Replay to do sports like cricket, soccer, basketball and other sports at a high level at times. The biggest issue is that I can't add clips from old recorded sessions or from clips exported from a previous session, either. There are times when I would want to import even the video elements into the session, but I would have to record it via an Output and map it into the replay session, which is time-consuming. Could we add a feature or a way for us to add these clips into the sessions better, or even the ability to link sessions together for a better workflow?
I look forward to this feature to be into a next vMix to come.
Cheers,
Adrian
thanks 1 user thanked Adriankey4 for this useful post.
furtive on 6/4/2026(UTC)
#2 Posted : Tuesday, February 24, 2026 5:54:29 AM(UTC)
Originally Posted by: Adriankey4 Go to Quoted Post
Good day, all.
Cheers,
Adrian
Please explain as seem to be missing the point as to why precisely.
Based on how a session data is kept i doubt a complete rewrite of the IR filing system is going to happen soon.
The nice thing though one can "pause" a session and continue later with the same one say multiple games in one session.
One can recall a previous session by "changing" the IR input (folder) and continue there also (but check the camera inputs used).
As for exported clips, why not just put them in a list to play back?
the ability to link sessions together i agree on (maybe but again why exactly in practise)
DJShaggyd
#3 Posted : Wednesday, May 20, 2026 8:50:46 PM(UTC)
DJShaggyd
South Africa
+1
furtive
#4 Posted : Thursday, June 4, 2026 2:49:54 AM(UTC)
furtive
Was thanked: 21 time(s) in 9 post(s)
Good day, all.
Cheers,
Adrian
To answer your question: there are many use cases for weaving ingested assets together with replay content in a playlist context. And, it's nice to have one UI for all of the countdowns and assets when possible.
The only way to gracefully do this, currently, is to record all of those assets to the replay drive (and clip them all out, and label them). This is time consuming and also must be re-done every session. Pretty much EVERY adopted replay solution in sports supports this, from EVS and Dreamcatcher all the way down to the more budget 3Play (even the older ones), because replay and playback are generally the same role
