Joined: 10/16/2025(UTC) Posts: 3  Location: manchester
Hi all
I've got a 1080p 60fps very basic project setup in vMix and Im seeing everyso often source drops on the Rode video Caster S, Cams set to 60, Rode set to 60 so no frame mismatches through the Rode into vMIx.(other UVC devices are doing the same)
RodeVideo Caster S vMix Pro 29 1 Replay 1 GT title
Asus TUF F15 Laptop 2022, 16GB Memory, Nvidia 3050TI 6GB GFX(set to Rebar, Max performance set) In vMix stats Render 5ms CPU 1% GPU 5% Total 11%
Replays on 2TB M2 drive Recordings on 1TB M2 drive (vmix and windows
Could the windows HDD be on its way out?
TIA
Joined: 10/20/2023(UTC) Posts: 161  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
For all video connections on the Asus TUF F15 2022, you must use capture cards on the Thunderbolt port because it is directly managed by the CPU BMD Ultrastudio or Thunderbolt PCIe Enclosure + capture card pcie
Thanks Kayo, but yes its plugged into the Thunderbolt port already. Just with it being such a basic vmix setup and hardly any usage on system resources im wondering if the drive is on its way out
Describe your setup between vMix and Rodecaster in more detail.
Maybe, but I don't think so. Test the SSD. And test it only in vMix, without Rodecaster. If there's no problem, then the link between vMix and Rodecaster is faulty.
