3rd Party Software and Development
[FREE] Scoreboard Engine (Clocks & Counters)
Joined: 9/14/2024(UTC) Posts: 8  Location: Sydney Was thanked: 2 time(s) in 2 post(s)
Scoreboard Engine 0.7.0 (Pocket Calculator Release)Released under the AGPL 3.0 License. Scoreboard Engine is an API-first server for scoreboards featuring an integrated web dashboard, JSON output for vMix Data Sources, Live updated web title hosting & helper, and full Bitfocus Companion module with all features. - View on GitHub- Download latest release from GitHub.Key Features- Single-Binary: Single executable, built in Rust for speed and robustness. - Full Bitfocus Companion module supporting all features. - Flexible: Configured with XML for as many widgets as you need. - Widgets: Timer, Counter, Text, List, Calculation - Disaster Recovery: Live state is persisted on every change and tick. - SSE Support: Get every tick and every change in realtime via HTTP Server Sent Events. - Live Audit: Every action is time-stamped in match_log.txt and mirrored to the stdout console. - JSON Data Source: Link to vMix titles using Data Sources - Integrated Dashboard: A HTML dashboard is baked directly into the executable. - Javascript Helper: Included Javascript helper library for easy HTML title creation. - Static Server: Serve custom HTML titles from a folder for use in OBS and as a web source/input. Integrated Dashboard:  vMix Data Sources:  vMix Title Example:  Example Companion Page:
Joined: 3/20/2026(UTC) Posts: 27  Location: Wilmington Thanks: 8 times Was thanked: 5 time(s) in 5 post(s)
Hi, jared.quinn! That's a cool idea. But I think all that functionality can be easily implemented using the internal features of vmix + stream deck.
Originally Posted by: Kotin  Hi, jared.quinn! That's a cool idea. But I think all that functionality can be easily implemented using the internal features of vmix + stream deck. I'm already doing it that way on several projects - but I wanted something a little more robust; a little more tightly integrated and convenient. It's ultimately designed for an environment where multiple instances may need to access the same authoritive data source, including other software like OBS or CasparCG (integrated customisable HTML templates with a JS helper to allow very easy HTML build of live updating templates). The next round of features will include a slave mode that can sync state between multiple instances and tracking of pause/stoppage time on timers.
