jared.quinn
#1 Posted : Wednesday, May 20, 2026 2:07:28 PM(UTC)
jared.quinn
Scoreboard Engine 0.7.0 (Pocket Calculator Release)
Released under the AGPL 3.0 License.
Scoreboard Engine is an API-first server for scoreboards featuring an integrated web dashboard, JSON output for vMix Data Sources, Live updated web title hosting & helper, and full Bitfocus Companion module with all features.
- View on GitHub
- Download latest release from GitHub.
Key Features
- Single-Binary: Single executable, built in Rust for speed and robustness.
- Full Bitfocus Companion module supporting all features.
- Flexible: Configured with XML for as many widgets as you need.
- Widgets: Timer, Counter, Text, List, Calculation
- Disaster Recovery: Live state is persisted on every change and tick.
- SSE Support: Get every tick and every change in realtime via HTTP Server Sent Events.
- Live Audit: Every action is time-stamped in match_log.txt and mirrored to the stdout console.
- JSON Data Source: Link to vMix titles using Data Sources
- Integrated Dashboard: A HTML dashboard is baked directly into the executable.
- Javascript Helper: Included Javascript helper library for easy HTML title creation.
- Static Server: Serve custom HTML titles from a folder for use in OBS and as a web source/input.
Dashboard Screenshot
vMix Data Sources:
vMix Data Sources
vMix Title Example:
vMix Title
Example Companion Page:
BitFocus Companion
Kotin
#2 Posted : Friday, May 22, 2026 3:47:44 AM(UTC)
Kotin
Hi, jared.quinn!
That's a cool idea.
But I think all that functionality can be easily implemented using the internal features of vmix + stream deck.
