accent-av
#1 Posted : Wednesday, January 15, 2025 1:29:55 AM(UTC)
accent-av
When creating a slide show with images, would love to request the option to have either a short list of transitions we can choose between pictures instead of just one type.
Or a random option that would include them all.
This would allow a bit of a more dynamic slide show with multiple transition effects between pictures.
Ideally, we can pick 4 or 5 transitions, but if not able to create a list of specific ones, then a random with all transitions would work.
mavik
#2 Posted : Thursday, January 16, 2025 4:10:59 PM(UTC)
mavik
+1 for a more dynamic image show. I can even think about a zoom/shift/rotate option and a blur fill if images don't fit the 16:9 area.
michealjames
#3 Posted : Monday, April 27, 2026 3:56:05 AM(UTC)
michealjames
+1 this would be a great addition. Even a simple “randomize transitions” toggle would make slideshows feel much more engaging without extra setup. A small set of customizable transitions would be even better
MickeyMJJ
#4 Posted : Wednesday, April 29, 2026 7:18:10 PM(UTC)
MickeyMJJ
+1
alens
#5 Posted : Tuesday, August 18, 2026 8:19:49 PM(UTC)
alens
Great suggestion being able to select multiple transitions or use a random transition mode would make image slideshows much more dynamic.
TL68
#6 Posted : Tuesday, August 18, 2026 11:43:23 PM(UTC)
TL68
Sweden
+1
