Feature Requests
Slide Show Multiple Transitions
Joined: 9/18/2020(UTC) Posts: 1  Location: Florida Thanks: 1 times
When creating a slide show with images, would love to request the option to have either a short list of transitions we can choose between pictures instead of just one type.
Or a random option that would include them all.
This would allow a bit of a more dynamic slide show with multiple transition effects between pictures.
Ideally, we can pick 4 or 5 transitions, but if not able to create a list of specific ones, then a random with all transitions would work.
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
+1 for a more dynamic image show. I can even think about a zoom/shift/rotate option and a blur fill if images don't fit the 16:9 area.
Joined: 4/27/2026(UTC) Posts: 1  Location: california
+1 this would be a great addition. Even a simple “randomize transitions” toggle would make slideshows feel much more engaging without extra setup. A small set of customizable transitions would be even better
Joined: 12/14/2018(UTC) Posts: 162   Location: Clermont-Ferrand Thanks: 37 times Was thanked: 9 time(s) in 8 post(s)
Joined: 8/18/2026(UTC) Posts: 1 Location: United States
Great suggestion being able to select multiple transitions or use a random transition mode would make image slideshows much more dynamic .
Joined: 12/8/2022(UTC) Posts: 165  Thanks: 50 times Was thanked: 3 time(s) in 3 post(s)
Feature Requests
