Feature Requests
Request: API Total Time Remaining in VideoList
Hello vMix team. Tried searching for similar requests and couldn't find any. I recently had the idea to implement a timer through a title input overlaid in a confidence monitor output that was filled out with a trigger via Companion to show the time remaining on a video playlist but quickly reached a limit since apparently there is only data for the currently selected video in a list. When I went to research if it could be done by the companion team, I ended up finding people who had similar ideas on GitHub and report it being an issue with the data not existing in the API of vMix. https://github.com/bitfo...diocoast-vmix/issues/181Picture for reference of which time stat I mean, also used in the GitHub post.  I hope this a relatively easy implementation, as it would be a great and easy way to implement a timer for the confidence monitor so a host or MC can easily see how much time is left on a currently playing video during an event.
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 65 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
Can you verify that you have enabled "Auto Next"? That button should show: where the play head is in the currently playing video / the duration of that video / the total time remaining in the list.
 1 user thanked vmixgreg for this useful post.
Originally Posted by: vmixgreg  Can you verify that you have enabled "Auto Next"? That button should show: where the play head is in the currently playing video / the duration of that video / the total time remaining in the list. Hey Greg, that feature definitely works inside vMix as intended. What I am looking for is for that information to also exist in the API so I can use it with Companion, as the total duration is not passed on to the following variable that I use $(vMix_Local:input_92b46fa6-d964-4a57-9d30-f149650c2726_remaining_mm.ss.ms), and there is according to one of the developer on GitHub no information on the total length of a playlist in the API.
Joined: 5/10/2022(UTC) Posts: 15  Location: Brisbane Thanks: 1 times
Joined: 4/3/2022(UTC) Posts: 38  Thanks: 7 times Was thanked: 21 time(s) in 9 post(s)
Joined: 2/23/2023(UTC) Posts: 77  Thanks: 24 times Was thanked: 11 time(s) in 4 post(s)
Feature Requests
