ChrisHoS
#1 Posted : Saturday, April 25, 2026 5:01:15 AM(UTC)
ChrisHoS
Denmark
Hello vMix team.
Tried searching for similar requests and couldn't find any.
I recently had the idea to implement a timer through a title input overlaid in a confidence monitor output that was filled out with a trigger via Companion to show the time remaining on a video playlist but quickly reached a limit since apparently there is only data for the currently selected video in a list.
When I went to research if it could be done by the companion team, I ended up finding people who had similar ideas on GitHub and report it being an issue with the data not existing in the API of vMix.
https://github.com/bitfo...diocoast-vmix/issues/181
Picture for reference of which time stat I mean, also used in the GitHub post.
I hope this a relatively easy implementation, as it would be a great and easy way to implement a timer for the confidence monitor so a host or MC can easily see how much time is left on a currently playing video during an event.
vmixgreg
#2 Posted : Saturday, April 25, 2026 5:21:41 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Can you verify that you have enabled "Auto Next"?
That button should show:
where the play head is in the currently playing video / the duration of that video / the total time remaining in the list.
thanks 1 user thanked vmixgreg for this useful post.
ChrisHoS on 4/25/2026(UTC)
ChrisHoS
#3 Posted : Saturday, April 25, 2026 6:44:49 AM(UTC)
ChrisHoS
Denmark
Hey Greg, that feature definitely works inside vMix as intended.
What I am looking for is for that information to also exist in the API so I can use it with Companion, as the total duration is not passed on to the following variable that I use $(vMix_Local:input_92b46fa6-d964-4a57-9d30-f149650c2726_remaining_mm.ss.ms), and there is according to one of the developer on GitHub no information on the total length of a playlist in the API.
Mr. Broadcast
#4 Posted : Wednesday, June 3, 2026 10:29:23 AM(UTC)
Mr. Broadcast
furtive
#5 Posted : Thursday, June 4, 2026 2:31:10 AM(UTC)
furtive
Was thanked: 21 time(s) in 9 post(s)
+1
ryxyz
#6 Posted : Thursday, June 4, 2026 6:01:02 AM(UTC)
ryxyz
Was thanked: 20 time(s) in 6 post(s)
+1
leandropricoli
#7 Posted : Saturday, June 6, 2026 12:01:12 AM(UTC)
leandropricoli
Brazil
+1
