I set up a raspberry pi 5 to receive an OMT feed from vMix today. It receives the video feed with no issues, it also reboots and starts automatically. The only issue I am having is there is not audio. I have checked vmix, the audio feeds are all unmuted. The tv the raspberry pi is connected to is unmuted and can play audio from the raspberry pi.
Is there a known issue with OMT not sending audio along with video at the moment? Or is there an issue with the Raspberry Pi configuration?
Currently running vMix 29.0.0.35 on Windows 11 Pro and OMT on Raspberry Pi 5 with Raspberry OS lite 64bit Debian bookworm (also tried Trixie).
Joined: 1/13/2010(UTC) Posts: 5,308  Location: Gold Coast, Australia Was thanked: 4703 time(s) in 1611 post(s)
The Raspberry Pi demos only supported video at this time.
However, as an open source project, we welcome other developers to contribute audio support to these projects.
Martin vMix
Joined: 5/19/2017(UTC) Posts: 101   Location: The Netherlands Thanks: 12 times Was thanked: 34 time(s) in 22 post(s)
I've added a PR that adds Audio Support. I used Codex to try and get it to work, after a pretty hefty prompt Codex went to work and added support for Audio. Just not sure if it's optimal code, so Martin should have to decide whether it's good enough to be merged into the main OMT Player project.
If Martin doesn't want to merge it, you could choose to pull my fork instead of the official omtplayer repo, but know that you're straying from the original project if you choose to do so and that Martin would have a good reason not to merge it.
