DutchieDavid
#1 Posted : Wednesday, November 5, 2025 11:04:23 AM(UTC)
DutchieDavid
Canada
I set up a raspberry pi 5 to receive an OMT feed from vMix today. It receives the video feed with no issues, it also reboots and starts automatically. The only issue I am having is there is not audio. I have checked vmix, the audio feeds are all unmuted. The tv the raspberry pi is connected to is unmuted and can play audio from the raspberry pi.
Is there a known issue with OMT not sending audio along with video at the moment? Or is there an issue with the Raspberry Pi configuration?
Currently running vMix 29.0.0.35 on Windows 11 Pro and OMT on Raspberry Pi 5 with Raspberry OS lite 64bit Debian bookworm (also tried Trixie).
#2 Posted : Wednesday, November 5, 2025 12:13:46 PM(UTC)
The Raspberry Pi demos only supported video at this time.
However, as an open source project, we welcome other developers to contribute audio support to these projects.
guidogast
#3 Posted : Saturday, April 11, 2026 7:10:21 PM(UTC)
guidogast
Netherlands
Was thanked: 36 time(s) in 24 post(s)
I've added a PR that adds Audio Support. I used Codex to try and get it to work, after a pretty hefty prompt Codex went to work and added support for Audio. Just not sure if it's optimal code, so Martin should have to decide whether it's good enough to be merged into the main OMT Player project.
If Martin doesn't want to merge it, you could choose to pull my fork instead of the official omtplayer repo, but know that you're straying from the original project if you choose to do so and that Martin would have a good reason not to merge it.
thanks 1 user thanked guidogast for this useful post.
jet on 4/12/2026(UTC)
#4 Posted : Monday, April 13, 2026 3:53:42 PM(UTC)
As luck would have it, I had already worked on audio support but didn't get a chance to do the final testing needed to release it.
This contribution from guidogast has motivated me to finally finish it and it can now be found below:
https://github.com/openmediatransport/omtplayer
Or if you would like to try the version from guidogast it can be found here:
https://github.com/guido-visser/omtplayer
thanks 3 users thanked admin for this useful post.
jet on 4/13/2026(UTC), doggy on 4/13/2026(UTC), guidogast on 4/14/2026(UTC)
guidogast
#5 Posted : Tuesday, April 14, 2026 7:34:28 PM(UTC)
guidogast
Netherlands
You're a legend Martin! Thank you so much!
I do recommend people to just use the main OMT Player project instead of my fork. If I run into problems of see cool new features that could be added, I'd might add them to the fork. If I think it will benefit a multitude of people, I will create a PR for them.
jet on 4/14/2026(UTC)
