Joined: 7/4/2016(UTC) Posts: 23  Location: Munich Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi there.
Will there be any notable performance impacts that a x8 PCIe 4.0 GPU connection can cause over a x16 PCIe 4.0 connection? Or asked differently: Can vMix take advantage of a x16 PCIe 4.0 over a x8 configuration.
CPU: Ryzen 9 5950X GPU: 5070TI
I'm just thinking about getting a Decklink 8k Pro Gen2 and if it's worth sacrifing x16 PCIE GPU connection for it. My workflow relies on NDI at most...so this 12G SDI are just nice to have for me. At least for recording 4 x 12G SDI Inputs with MultiCorder though.
Thanks for any advice.
Have a happy easterš£
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Hi, no impact = 1% test with 5090  relative-performance-3840-2160.png (279kb) downloaded 70 time(s).
Thanks Kayo,
but these are about typical GPU loads (gaming) But I'm afraid that it would be different when doing a lot of MultiCorder (4k) or recording as there are many bus transfers happening. Isn't it?
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
although I run intel CPUs, i've been running x8/x8 config for several years now splitting between GPU and a Decklink Quad2. Can't say I've ever noticed any performance issues. I run shows with >100 inputs, 8 ch replay, 8 ch multicorder, etc so think I'd notice if the GPU was choking.
The resources needed for 1 x 4K 60p = 2 x 4K 30p Referring to the Topaz system, you can get an idea Contact vMix support to see if they have already tested it on their system
