majorsky
#1 Posted : Sunday, April 5, 2026 11:45:53 AM(UTC)
majorsky
Hi there.
Will there be any notable performance impacts that a x8 PCIe 4.0 GPU connection can cause over a x16 PCIe 4.0 connection?
Or asked differently: Can vMix take advantage of a x16 PCIe 4.0 over a x8 configuration.
CPU: Ryzen 9 5950X
GPU: 5070TI
I'm just thinking about getting a Decklink 8k Pro Gen2 and if it's worth sacrifing x16 PCIE GPU connection for it.
My workflow relies on NDI at most...so this 12G SDI are just nice to have for me. At least for recording 4 x 12G SDI Inputs with MultiCorder though.
Thanks for any advice.
Have a happy easter🐣
Kayo33
#2 Posted : Sunday, April 5, 2026 3:00:12 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
no impact = 1%
test with 5090
majorsky
#3 Posted : Sunday, April 5, 2026 10:13:17 PM(UTC)
majorsky
Thanks Kayo,
but these are about typical GPU loads (gaming)
But I'm afraid that it would be different when doing a lot of MultiCorder (4k) or recording as there are many bus transfers happening. Isn't it?
AudioGreg
#4 Posted : Tuesday, April 7, 2026 5:35:25 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
although I run intel CPUs, i've been running x8/x8 config for several years now splitting between GPU and a Decklink Quad2. Can't say I've ever noticed any performance issues. I run shows with >100 inputs, 8 ch replay, 8 ch multicorder, etc so think I'd notice if the GPU was choking.
Kayo33
#5 Posted : Tuesday, April 7, 2026 5:38:53 PM(UTC)
Kayo33
The resources needed for 1 x 4K 60p = 2 x 4K 30p
Referring to the Topaz system, you can get an idea
Contact vMix support to see if they have already tested it on their system
Guest (4)
