jello
#1 Posted : Sunday, October 13, 2024 2:04:15 PM(UTC)
jello
I need a method for either accessing the zoomchat data directly... or to add functionality allowing someone to call the last X rows.
I am trying to create a giant running chat window (a vertical 80" display) that our faculty can see while they are teaching... the last 10 or so chats, newest on top.
Currently, Zoomchat is just presented as a datasource. We can access the chats one row at a time, but we can't do anything more because there is no file or accessible source to manipulate by script... as there would be for other datasources xml, google sheets, etc.
For my purposes, I just need a way to get at the data... I can figure something out from there.
But it would be nicer if there were some multi-line data display options in vMix like "display Last X rows" or other filters, sql command or whatever.
(If this is sounding familiar, we talked about it at NAB.)
Thank you!
spinfold
#2 Posted : Sunday, October 13, 2024 4:15:18 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
Thank you!
I haven't used Zoom chat data as a datasource, but I have before used the same datasource to show multiple rows, by adding the datasource multiple times in the data manager. Is that something you can do with the Zoom chat data source?
Josemite
#3 Posted : Friday, October 18, 2024 7:29:42 AM(UTC)
Josemite
I've been trying to figure out a way to pull this off too. If I could somehow sort where the last chat comment was instead the 1st line in the data source (instead of the last, as it is now) it would be simple. The problem that I can't work around is that the latest comment appends vs prepends, so it's always a different row number.
Of course I can get the latest one to show up with auto-next, but I can't get the latest 5 or 10 chats to stay up. As I'd need to lock in what rows they were, but that is always changing.
An option to prepend vs append would solve it, or some other kind of persistent sorting option for like time.
Thank you!
jello
#4 Posted : Friday, December 13, 2024 2:34:06 AM(UTC)
jello
Just refreshing this one.
Again, the ZoomChat is the only kind of datasource that we can't interact with outside of vMix, and doing anything meaningful with it inside vMix is difficult if not impossible.
If vMix would write the chat out to json or xml, or make it possible to make have more meaningful interactions with datasources inside vMix, either would be a big help.
Josemite
#5 Posted : Friday, December 20, 2024 8:28:49 AM(UTC)
Josemite
That would be really cool. However, I'd be happy if it just held its 'Received' sorting options in Data Sources, so I could have it prepend instead of append new messages.
Then I could display the latest 5 messages by using the rows 1-5.
As it is, I can't do anything but use the auto-next to display the very last message.
Josemite
#6 Posted : Thursday, April 2, 2026 2:49:06 PM(UTC)
Josemite
Thank you!
If you haven't found a solution, there is a thing called Zoom Graphics Toolkit (Zoom just bought them). This gives you a way to display the Zoom chat as a local HTML page, and bring it in as a webpage into vMix. It has a lot of options and abilities to customize.
One draw back though, is you can't use it and the vMix Zoom plugin at the same time (think it shares the same SDK). So there is still a need for vMix to change something with the data source management. Either change the sorting order to have the newest chat messages prepended to the first row. Or give us a way for the data sorting to stick, so we can sort by the time column and keep newest first.
