Joined: 4/1/2026(UTC) Posts: 3   Location: Araguari-MG
Recently I upgraded my Geforce graphics card (RTX 4070 to RTX 5070Ti). After this upgrade, problems started occurring in my streaming: the first time I stream, the sound is completely distorted, as if there were encoding problems. The video also looks like it's in slow motion. To solve the problem, I disconnect the stream and restart it, and everything goes back to normal. But the problem can happen at unexpected times during the stream. I've already looked for all kinds of solutions, with changes in streaming modes, settings on my computer (which is an i9 14900k, with 32 GB of memory), but nothing works. Before the graphics card upgrade, my streams were perfect. I tested the stream with another program and no problems occurred. Is anyone experiencing a similar situation and has found a solution? Below I posted a video with this problem: https://drive.google.com...6EPBLB5NSomjSt3jGhl/viewThanks.
Joined: 11/23/2020(UTC) Posts: 241  Location: Wichita Thanks: 11 times Was thanked: 31 time(s) in 27 post(s)
Originally Posted by: doctordj  Recently I upgraded my Geforce graphics card (RTX 4070 to RTX 5070Ti). After this upgrade, problems started occurring in my streaming: the first time I stream, the sound is completely distorted, as if there were encoding problems. The video also looks like it's in slow motion. To solve the problem, I disconnect the stream and restart it, and everything goes back to normal. But the problem can happen at unexpected times during the stream. I've already looked for all kinds of solutions, with changes in streaming modes, settings on my computer (which is an i9 14900k, with 32 GB of memory), but nothing works. Before the graphics card upgrade, my streams were perfect. I tested the stream with another program and no problems occurred. Is anyone experiencing a similar situation and has found a solution? Below I posted a video with this problem: https://drive.google.com...6EPBLB5NSomjSt3jGhl/viewThanks. javascript:__doPostBack('forum$ctl03$PostReply','') Try rolling back the driver to the same version that you used with the 4070, it may be a driver version problem. Are you using the Creator driver or the Gaming one? That might make the difference as well.
I was using the gaming version but updated to the creator version. The problem occurred in both versions.
The problem now is getting the previous driver because the Nvidia app updates the driver and I haven't been able to locate where the drivers are downloaded yet.
When I changed the video cards, the Nvidia app automatically requested the update.
I'll try to find the old driver and see if that solves it.
Joined: 10/20/2023(UTC) Posts: 157  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: doctordj  I was using the gaming version but updated to the creator version. The problem occurred in both versions.
I'll try to find the old driver and see if that solves it. https://www.nvidia.com/pt-br/drivers/
@ doctordj
Recent NVIDIA drivers require FFMPEG6 in vMix, can you verify you are using that that?
Joined: 10/10/2019(UTC) Posts: 63   Location: Düsseldorf Thanks: 3 times Was thanked: 14 time(s) in 8 post(s)
I've tried every possible change: I reverted to the driver before the video card change, used FFMPEG6 in vMix, used the most basic vMix settings, uninstalled and reinstalled vMix, and none of them solved the problem. The only thing left to do is to put the RTX 4070 video card back in or test vMix on another computer, but I don't have a software license for that. To continue my broadcasts, the only option would be to start the broadcast, disconnect and reconnect, and hope the problem doesn't happen during the broadcast, or use other software (which is what I'm doing for now). Thanks.
Originally Posted by: doctordj  I've tried every possible change: I reverted to the driver before the video card change, used FFMPEG6 in vMix, used the most basic vMix settings, uninstalled and reinstalled vMix, and none of them solved the problem. The only thing left to do is to put the RTX 4070 video card back in or test vMix on another computer, but I don't have a software license for that. To continue my broadcasts, the only option would be to start the broadcast, disconnect and reconnect, and hope the problem doesn't happen during the broadcast, or use other software (which is what I'm doing for now). Thanks. You can have one vMix license set up on two computers at the same time, that allows you to use another system to work out issues like this before you bring them to your production machine.
Joined: 2/4/2025(UTC) Posts: 15  Location: Tennessee Was thanked: 1 time(s) in 1 post(s)
I have a 5070 ti as well. You can uninstall the nvidia app. Its not needed. Id download the latest drivers and during the install process choose custom and clean install. While streaming bring up task manager and go to performance. Look to see if CPU or GPU are being overloaded. Also look at your network speeds. See if its network traffic matches your stream upload speed. In Vmix look at your performance stats. Make sure its not dropping frames. Try streaming in HEVC or AV1. AV1 if not doing HDR. In stream settings make sure use hardware encoder is selected. In preset use P1 fastest. Audio format AAC. Make sure your computer isnt using some sort of onboard graphics. I doubt it since this appears to be a desktop. Also check to make sure the output FPS and vmix preset match your video. You sound like you should have PAL settings. Vmix could default to NTSC framerates.
DeanJohnsonProductions brought up network. Have you checked to make sure you are getting at least 1000Kbps on your network and that means from your Camera to the PC interface and from the PC to the switch or router and through every switch and router you have between the PC and the internet.
Because those network connections will happily degrade WITHOUT TELLING YOU and when the network won't support the activity it's easy to be looking at the wrong thing as the problem. Also if your interface between the camera and the PC goes through a USB port make sure it's a USB 3.0 or later port it's connected to.
