TL68
#1 Posted : Wednesday, March 4, 2026 1:22:06 AM(UTC)
TL68
Sweden
Hi!
As the title says: I wonder if it is possible to use an event inside a title created with GT Title to make a trigger that can do other functions in vMix?
In this specific case I would like to use an animation on an object in a title to make a trigger that then can turn an overlay in vmix off.
Thanks in advance for any help with this!
#2 Posted : Wednesday, March 4, 2026 3:58:18 AM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi!
https://www.vmix.com/help29/Triggers.html
Roy Sinclair
#3 Posted : Thursday, April 2, 2026 7:51:31 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Hi!
There are no triggers for animation events inside titles..... BUT if the animation event happens at a fixed time after the title is displayed then you can use the "onOverlayIn" trigger with a fixed delay that is set to start when the animation event should occur.
thanks 1 user thanked Roy Sinclair for this useful post.
TL68 on 4/2/2026(UTC)
