Is it possible to create a trigger based on an animation event inside a title?
Joined: 12/8/2022(UTC) Posts: 168  Thanks: 52 times Was thanked: 3 time(s) in 3 post(s)
Hi! As the title says: I wonder if it is possible to use an event inside a title created with GT Title to make a trigger that can do other functions in vMix? In this specific case I would like to use an animation on an object in a title to make a trigger that then can turn an overlay in vmix off.
Thanks in advance for any help with this!
Originally Posted by: TL68  Hi! As the title says: I wonder if it is possible to use an event inside a title created with GT Title to make a trigger that can do other functions in vMix? In this specific case I would like to use an animation on an object in a title to make a trigger that then can turn an overlay in vmix off.
https://www.vmix.com/help29/Triggers.html
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
There are no triggers for animation events inside titles..... BUT if the animation event happens at a fixed time after the title is displayed then you can use the "onOverlayIn" trigger with a fixed delay that is set to start when the animation event should occur.
 1 user thanked Roy Sinclair for this useful post.
