Almeida
#1 Posted : Thursday, March 26, 2026 7:32:19 AM(UTC)
Almeida
Brazil
Good afternoon everyone, we're using 3 PTZ cameras via NDI in a podcast.
Strangely, they've started lagging, but only in vMix. We tested it in OBS and it ran smoothly. Has anyone else experienced this? If so, please share how you solved it.
Updated license,
Roy Sinclair
#2 Posted : Thursday, April 2, 2026 7:36:10 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Updated license,
Check your Network connections, especially at the PC. You may have a 100mbps connection instead of a 1000mbps (Gigabit). Gigabit is recommended minimum speed.
Almeida
#3 Posted : Thursday, April 2, 2026 8:22:40 AM(UTC)
Almeida
Brazil
Hi Roy, We checked and everything was normal. I remember that the power in the room was fluctuating, could that be influencing it?
Roy Sinclair
#4 Posted : Thursday, April 9, 2026 7:41:46 AM(UTC)
Roy Sinclair
Absolutely, with fluctuating power all manners of equipment could be crashing and restarting andi for network equipment that could cause it to lag.
mavik
#5 Posted : Thursday, April 9, 2026 7:35:19 PM(UTC)
mavik
Check if the NDI is without issues in Studio Monitor. This is the reference.
Kayo33
#6 Posted : Friday, April 10, 2026 2:47:52 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Updated license,
What is your PC configuration? (motherboard + CPU + RAM + GPU)
Almeida
#7 Posted : Friday, April 10, 2026 4:43:35 AM(UTC)
Almeida
Brazil
Dell G15 i7 12th Generation, 16GB RAM - RTX 3050
Kayo33
#8 Posted : Friday, April 10, 2026 6:17:08 AM(UTC)
Kayo33
maybe update drivers
https://www.dell.com/sup...s-15-5520-laptop/drivers
or reinstalling Windows
Almeida
#9 Posted : Saturday, April 11, 2026 12:08:23 AM(UTC)
Almeida
Brazil
It only happened at that specific event; after that, we did four more transmissions in the same format and everything went well. Now we always run an HDMI fiber optic cable along with the RJ45 cable, haha.
Almeida
#10 Posted : Saturday, April 11, 2026 12:12:08 AM(UTC)
Almeida
Brazil
@Mavik--- At the time of the incident, we checked the NDI stream through Studio Monitor @Mavik, including in OBS. It was running perfectly, which leads me to believe it's something related to vMix :(
