KeithB
#1 Posted : Saturday, May 15, 2021 8:23:12 PM(UTC)
KeithB
Canada
When soloing any audio inputs, or buss, the audio is post fader so represents the actual level setting.
In the case of the master output, the level is pre fader. Not sure why.
This led to an error on a web cast where the master mix was heard in the headphones but the master fader was down so no audio to the live stream!
The ask here is set master audio monitoring to post fader. (or an explanation as to what the benefit is to a pre fade master)
lindend
#2 Posted : Monday, August 2, 2021 1:36:34 AM(UTC)
lindend
We had the exact same issue yesterday streaming our church service. Was listening to the monitor audio and thought everything was ok. The master was muted so our viewers heard nothing and were posting like crazy that there was no audio. Was really short handed so it took a while to realize the problem and even longer to realize that the master was muted.
Would REALLY love for the monitor to be post all audio processing so we can hear what the viewers will be hearing.
gyarnell
#3 Posted : Thursday, December 2, 2021 3:59:46 AM(UTC)
gyarnell
Yes, same problem. We have to watch the visual output level indicator to try to balance our streamed output. Monitor via headphones doesn't help.
gyarnell
#4 Posted : Wednesday, May 18, 2022 7:31:14 AM(UTC)
gyarnell
I figured out a work-around to this problem. We have a pretty simple setup, so the work-around may not work if your setup is more complex.
Inputs:
PTZ Camera
Audio mixer board
Powerpoint slides
MP4 video
I ended up connecting all audio inputs to channel A as well as the Master output. I configured channel A output to a set of headphones. Enabling channel A adds its fader to the internal mixer. I configured the Master and channel A outputs identically using the Gear, and set their faders to the same levels.
Since our setup is pretty simple, we balance the individual mics attached to the sound board on the sound board. I can now adjust the sound board input slider and monitor vMix output using the channel A headphones. Same goes for the audio level from the MP4 video input.
Greg Y.
knbPixels
#5 Posted : Friday, May 9, 2025 10:27:26 PM(UTC)
knbPixels
+1
spinfold
#6 Posted : Saturday, May 10, 2025 2:14:36 AM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
Originally Posted by: knbPixels Go to Quoted Post
+1
This is an old thread and PFL (pre fader) was introduced in v27.
mavik
#7 Posted : Monday, May 12, 2025 6:47:35 PM(UTC)
mavik
I use a button on the stream deck with an activator to get the master audio status and adding a shortcut master audio is easy to see and resolve.
knbPixels
#8 Posted : Wednesday, May 21, 2025 4:37:00 AM(UTC)
knbPixels
+1
How does the addition of PFL relate to an option to make the master headphone output be post fader audio?
knbPixels
#9 Posted : Wednesday, May 21, 2025 5:52:24 AM(UTC)
knbPixels
That doesn't solve the issue...we need the ability to listen to master out from the headphone output where the mix is not all the assigned input pre-fader. It makes no sense if we can solo channels and listen PFL to channels individually, and the master headphones output is all inputs assigned to master, but still prefader level. IMHO Master out listen should always be post fader level, so you are listening to what it actually being send to master.
TracyPeterson
#10 Posted : Wednesday, October 8, 2025 2:12:11 AM(UTC)
TracyPeterson
This just bit me on a show. I had always considered the headphones to be like a mixing console headphones, which is a post fader monitor of mains (selectable on some consoles) with the ability to solo inputs for monitoring.
At no point have I encountered anywhere else, a monitor output that was pre fade on master unless selected, all default to pre.
On a show, I had to mute master to keep open mics from stream, at that time I didn't notice that I was still hearing inputs, as my headphones were off. Later when I came back to next session, I could hear music, etc, so I assumed the stream and records did as well. They did not.
Headphones should be master post fade, unless master is solo'd.
Feature request:
Headphones output DEFAULTS to master post fader, unless bus/inputs are solo'd
Master has an added SOLO button for pre-fade listen in case output needs to be muted.
None of these requests are solved by former pre fader option additions.
mormiguel
#11 Posted : Thursday, March 26, 2026 3:53:33 AM(UTC)
mormiguel
Spain
This is super weird because I have been using Vmix for years and I have been able to listen to the audio from the master bus but today I couldn't and it started working as TracyPeterson says: the headphone output is pre-fader of the master output.
What could have changed? Should the audiodevices of the master and headphones in the "audio ouput" section be different?
Anyone has been able to solve this?
elvis55
#12 Posted : Thursday, March 26, 2026 6:31:01 AM(UTC)
elvis55
Switzerland
Master Output
Select the output to send the Master audio mix to. This is the default audio mix
used for streaming, recording and external output.
Headphones
Select the output to send the Headphones audio mix to.
This mix is the same as Master Output except when Solo is enabled on an input.
When Solo is enabled on an input only that input will be heard.
knbPixels
#13 Posted : Saturday, March 28, 2026 12:16:24 AM(UTC)
knbPixels
Originally Posted by: elvis55 Go to Quoted Post
Master Output
Headphones
Yes that is how it is currently designed to work, which is not in dispute. So how does one have the option of listening to the Master level from the headphones output and have a true ability to monitor it, if the headphone output is pre-fader level of the master? The only way to listen to the actual Master output and take the Master level gain into account is to listen to it outside of vMix. Show me a single audio console where you can't monitor the main output post fader. There's a reason for it.
