CoryL.NFLD
#1 Posted : Thursday, March 19, 2026 10:11:50 AM(UTC)
CoryL.NFLD
Canada
I have 85 separate videos that will air during a 9 hour broadcast. I'd like each of them to on completion switch to what's in the preview window using a stinger as a transition. I have it working using triggers "OnCompletion, Stinger1, Preview". Adding this trigger to 85 videos is a tedious and time-consuming process. Does anyone know a better way? I've tried using a script but can't seem to get that working. Any thoughts?
Thanks!
dmwkr
#2 Posted: : Thursday, March 19, 2026 7:04:55 PM(UTC)
dmwkr
Thanks!
A better way could be putting the videos into one list input. :)
thanks 1 user thanked dmwkr for this useful post.
Kotin on 3/22/2026(UTC)
#3 Posted : Thursday, March 19, 2026 7:13:38 PM(UTC)
Thanks!
IMO Using a stinger with a OnCompletion trigger doesn't look nice as one sees the current video paused first before the stinger is actually activated
mavik
#4 Posted : Thursday, March 19, 2026 10:05:59 PM(UTC)
mavik
Adding the video will exhaust the GPU mem so a simple solution is the list input.
Another approach is to use a single input add the trigger and stuff and change the video file.
Kotin
#5 Posted : Sunday, March 22, 2026 9:36:25 AM(UTC)
Kotin
Thanks!
But, in the sheet, you can't configure a transition through a stinger. As I understand it, this is exactly what the author needs.
dmwkr
#6 Posted : Monday, March 23, 2026 7:43:43 PM(UTC)
dmwkr
Don't know what you mean. You can set up the stinger transition as a trigger, and the OP already did it successfully. He is just looking for an easy way to set it up for all 85 videos.
