Joined: 6/26/2024(UTC) Posts: 2  Location: NFLD Thanks: 1 times
I have 85 separate videos that will air during a 9 hour broadcast. I'd like each of them to on completion switch to what's in the preview window using a stinger as a transition. I have it working using triggers "OnCompletion, Stinger1, Preview". Adding this trigger to 85 videos is a tedious and time-consuming process. Does anyone know a better way? I've tried using a script but can't seem to get that working. Any thoughts?
Thanks!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: CoryL.NFLD  I have 85 separate videos that will air during a 9 hour broadcast. I'd like each of them to on completion switch to what's in the preview window using a stinger as a transition. I have it working using triggers "OnCompletion, Stinger1, Preview". Adding this trigger to 85 videos is a tedious and time-consuming process. Does anyone know a better way? I've tried using a script but can't seem to get that working. Any thoughts?
Thanks! A better way could be putting the videos into one list input. :)
 1 user thanked dmwkr for this useful post.
Thanks! IMO Using a stinger with a OnCompletion trigger doesn't look nice as one sees the current video paused first before the stinger is actually activated
Adding the video will exhaust the GPU mem so a simple solution is the list input.
Another approach is to use a single input add the trigger and stuff and change the video file.
Joined: 3/20/2026(UTC) Posts: 34  Location: Wilmington Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: dmwkr  Originally Posted by: CoryL.NFLD  I have 85 separate videos that will air during a 9 hour broadcast. I'd like each of them to on completion switch to what's in the preview window using a stinger as a transition. I have it working using triggers "OnCompletion, Stinger1, Preview". Adding this trigger to 85 videos is a tedious and time-consuming process. Does anyone know a better way? I've tried using a script but can't seem to get that working. Any thoughts?
Thanks! A better way could be putting the videos into one list input. :) But, in the sheet, you can't configure a transition through a stinger. As I understand it, this is exactly what the author needs.
But, in the sheet, you can't configure a transition through a stinger. As I understand it, this is exactly what the author needs. Don't know what you mean. You can set up the stinger transition as a trigger, and the OP already did it successfully. He is just looking for an easy way to set it up for all 85 videos.
