youcci
#1 Posted : Wednesday, February 18, 2026 8:32:04 PM(UTC)
youcci
Germany
I’m running multiple infoscreens using BirdDog Play devices and frequently need to switch NDI sources remotely — especially in production or event environments where opening the control panel for each device always is inpractical.
To solve this, I built a small mobile app that lets you remotely control:
BirdDog Play
NDI Studio Monitor
from iOS or Android.
What it does:
Discover NDI receivers on the network
Switch NDI sources remotely
Control fullscreen output
Manage playback without touching the device
Works great for multi-screen / digital signage setups
It has been very helpful in mosque/event production setups and multi-room environments where quick switching is required.
If anyone here is using BirdDog Play or Studio Monitor for monitoring, confidence feeds, or infoscreens — this might save you some time.
iOS:
https://apps.apple.com/u...reen-remote/id6758415826
Android:
https://play.google.com/...?id=com.youcci.ndiremote
I’m happy to hear feedback or feature requests from the vMix community šŸ‘
