Joined: 11/14/2021(UTC) Posts: 4  Location: Pittsburgh
Ive used VMix for playback to a BMD 3g monitor. A couple times now when I test the playback the sync is fine but a few hours later when I play some thing, the audio is out of sync. I can correct it with the audio settings, but I'm not sure what exactly is causing it or how to prevent it. I'm using the external output at 1080i59.9. I could understand a little drift as the playback progresses, but I notice it shortly after restarting the playback.
Joined: 11/14/2012(UTC) Posts: 402  Location: Finland Thanks: 255 times Was thanked: 39 time(s) in 37 post(s)
vMix version? OS version? Hardware specs? BMD Driver version? ("Desktop Video") etc..
And is the "BMD 3G Monitor" box the newer one with the Thunderbolt3 connection (usb-c -like)? And how is this connected to the PC? Does the PC- have Thunderbolt3/4 support and is the cable real Thuderbolt cable or regular "ucb-c" cable?
VMix 29.0.0.41, although it happened on an version a few months ago as well Win 11 Pro (up to date, but I don't know the exact build when it happened) MSI GS75 Stealth i7-10875H @2.3Ghz 32GB ram NVidia GForce RTX 2070 BMD Desktop Video 14.0.1 It's the BMD 3G Monitor connected to thunderbolt via thunderbolt cable. I also have an UltraStudio 4k and a Decklink 8k Pro in a Thunderbolt enclosure, but I think both times I noticed this happening it was with the 3G
