Zoom – Force vMix as the only visible source
Joined: 1/9/2026(UTC) Posts: 2  Location: Linz Thanks: 1 times
We are currently testing vMix in combination with Zoom Webinar and Webinar PLUS (one-to-many setup). Our objective is to ensure that attendees see only the vMix transmission (e.g., Output 1) as a clean feed, without any additional Zoom UI overlays, duplicate participant windows, or automated view switching.
Current Issues: - Duplicate Participant Feeds: When a presenter joins the Zoom meeting, their camera is displayed twice: once as part of our composed vMix layout and a second time as a native Zoom camera feed (Gallery/Speaker view). - Screen Share Overlays: When a participant uses the native Zoom screen share, a small window appears on top of our main feed, even though we are already capturing and broadcasting that screen content through vMix. - Inconsistent View Switching: Occasionally, the Zoom view layout changes unexpectedly, minimizing the vMix output to a small thumbnail and focusing on a different participant's camera.
What we have tried so far: We have experimented with the Spotlight feature and various view configurations within the Zoom client, but we haven't found a combination that forces a "clean feed" for all attendees.
Our Question: Is there a specific configuration within the vMix Zoom Plugin or the Zoom Admin settings to force the vMix output as the sole and exclusive source for all attendees, preventing Zoom from injecting any additional overlays or switching the focus?
Software Environment: vMix: UHD v28 & v29 vMix Zoom Plugin: v6.0.11 Zoom License: Webinars & Webinars PLUS
Thanks in advance for your help!
Best regards Hans-Peter
Joined: 2/7/2024(UTC) Posts: 166  Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Have you tried having the panelists join a regular zoom meeting and sending out your output to Zoom via NDI so that the webinar experience is "cleaner"? You likely would need VB cable or something to bring the audio over
Joined: 4/23/2017(UTC) Posts: 1,413  Location: Germany Thanks: 3 times Was thanked: 187 time(s) in 167 post(s)
If zoom isn't the 100% fit try to take MS Teams with NDI enabled. I do this all the time and it works just great. I have a normal teams meeting for the presenters. Grab them via NDI and use the vMix output for whatever I need. A Teams Townhall, a webinar, a livestream for vimeo or any social platform. I use output two and a greenroom bus as the return feed into the meeting. This way I can overlay a timer or any other specials they wish to see. I set the return feed to spotlight for all so that every presenter has the program out in view.
Joined: 5/14/2013(UTC) Posts: 150  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
I do one a few times a year where the presenters are on zoom with the Vmix integration then we send out to a teams webinar /town hall or whatever it’s called this week , the teams producer gui is allows just our feed to be broadcast
 1 user thanked Henny for this useful post.
First of all, sorry for the delay in my reply
We have gathered quite a bit of experience over the last few days. Here are our key findings: In Short: Clean feed works in Webinar PLUS
- Zoom Webinar PLUS & vMix: To use Webinar PLUS features, vMix 29 and the latest Zoom vMix plugin are mandatory. Otherwise, it simply doesn't work (normal Webinars works with join meeting - and Webinar PLUS with join event) - Zoom Production Tools: These tools work excellently and generally solve our "clean feed" problem. However, they are only available in Webinar PLUS (and likely Zoom Events), which makes them a more expensive and not always a universal solution for every event. - I saw that zoom and NDI also work on MAC only. So there would be another "professional" solution, but we didn't test it yet
Screen Sharing Performance: We are seeing very poor results with native screen sharing, typically around 5 fps. Even enabling "High Fidelity" mode did not result in any noticeable improvement in our tests.
and for Microsoft Teams (we are using it internally) - Using Teams with external participants is problematic for us. The security settings are managed centrally by corporate IT, which means functionality can change (or break) from one day to the next without warning. At the moment we can't use chat or q&a features - Teams is limited with their features. Zoom or GoTo are way more suitable
