AVWKOOÖ
#1 Posted : Friday, January 9, 2026 2:34:21 AM(UTC)
AVWKOOÖ
Austria
We are currently testing vMix in combination with Zoom Webinar and Webinar PLUS (one-to-many setup). Our objective is to ensure that attendees see only the vMix transmission (e.g., Output 1) as a clean feed, without any additional Zoom UI overlays, duplicate participant windows, or automated view switching.
Current Issues:
- Duplicate Participant Feeds: When a presenter joins the Zoom meeting, their camera is displayed twice: once as part of our composed vMix layout and a second time as a native Zoom camera feed (Gallery/Speaker view).
- Screen Share Overlays: When a participant uses the native Zoom screen share, a small window appears on top of our main feed, even though we are already capturing and broadcasting that screen content through vMix.
- Inconsistent View Switching: Occasionally, the Zoom view layout changes unexpectedly, minimizing the vMix output to a small thumbnail and focusing on a different participant's camera.
What we have tried so far:
We have experimented with the Spotlight feature and various view configurations within the Zoom client, but we haven't found a combination that forces a "clean feed" for all attendees.
Our Question:
Is there a specific configuration within the vMix Zoom Plugin or the Zoom Admin settings to force the vMix output as the sole and exclusive source for all attendees, preventing Zoom from injecting any additional overlays or switching the focus?
Software Environment:
vMix: UHD v28 & v29
vMix Zoom Plugin: v6.0.11
Zoom License: Webinars & Webinars PLUS
Thanks in advance for your help!
Best regards Hans-Peter
knbPixels
#2 Posted : Friday, January 9, 2026 10:31:15 PM(UTC)
knbPixels
Have you tried having the panelists join a regular zoom meeting and sending out your output to Zoom via NDI so that the webinar experience is "cleaner"? You likely would need VB cable or something to bring the audio over
mavik
#3 Posted : Sunday, January 11, 2026 4:52:58 AM(UTC)
mavik
If zoom isn't the 100% fit try to take MS Teams with NDI enabled. I do this all the time and it works just great. I have a normal teams meeting for the presenters. Grab them via NDI and use the vMix output for whatever I need. A Teams Townhall, a webinar, a livestream for vimeo or any social platform. I use output two and a greenroom bus as the return feed into the meeting. This way I can overlay a timer or any other specials they wish to see. I set the return feed to spotlight for all so that every presenter has the program out in view.
Henny
#4 Posted : Monday, January 12, 2026 8:24:52 AM(UTC)
Henny
I do one a few times a year where the presenters are on zoom with the Vmix integration then we send out to a teams webinar /town hall or whatever it’s called this week , the teams producer gui is allows just our feed to be broadcast
thanks 1 user thanked Henny for this useful post.
AVWKOOÖ on 1/16/2026(UTC)
AVWKOOÖ
#5 Posted : Friday, January 16, 2026 2:49:53 AM(UTC)
AVWKOOÖ
Austria
First of all, sorry for the delay in my reply
We have gathered quite a bit of experience over the last few days. Here are our key findings:
In Short: Clean feed works in Webinar PLUS
- Zoom Webinar PLUS & vMix: To use Webinar PLUS features, vMix 29 and the latest Zoom vMix plugin are mandatory. Otherwise, it simply doesn't work (normal Webinars works with join meeting - and Webinar PLUS with join event)
- Zoom Production Tools: These tools work excellently and generally solve our "clean feed" problem. However, they are only available in Webinar PLUS (and likely Zoom Events), which makes them a more expensive and not always a universal solution for every event.
- I saw that zoom and NDI also work on MAC only. So there would be another "professional" solution, but we didn't test it yet
Screen Sharing Performance: We are seeing very poor results with native screen sharing, typically around 5 fps. Even enabling "High Fidelity" mode did not result in any noticeable improvement in our tests.
and for Microsoft Teams (we are using it internally)
- Using Teams with external participants is problematic for us. The security settings are managed centrally by corporate IT, which means functionality can change (or break) from one day to the next without warning. At the moment we can't use chat or q&a features
- Teams is limited with their features. Zoom or GoTo are way more suitable
AVWKOOÖ
#6 Posted : Wednesday, January 28, 2026 8:46:49 PM(UTC)
AVWKOOÖ
Austria
Update
our problems added up - the clean feed is/was later our smallest problem. Lucky for us we got the Zoom Suoltion Team that help us understand that we can't use vMix as intendet.
But this should change in a few weeks because Zoom is working so that 3rd party vendors get a better connection (API)
We had/have several mission-critical issues regarding the integration of vMix within our Zoom (incl. Webinar Plus and Production Studio) environment. Below is the worst.
1. Clean-Feed Constraints and Screen Share Routing
Maintaining a professional "Clean-Feed" currently presents a conflict between visual integrity and audio control:
Without Production Studio (Image 1): Screen sharing results in redundant displays. The share appears both as a native Zoom overlay and within the vMix signal, making a clean broadcast feed impossible.
With Production Studio (Image 2): While this allows for a clean feed (see config in Images 3 & 4), it breaks the audio workflow. Screen share audio is not transmitted to the vMix ingest unless the share is added as an active source in a Production Studio scene.
The Conflict: Adding the share directly to the Studio forces it "Live" for attendees immediately, bypassing vMix as the production switcher and eliminating our ability to manage the layout.
Requirement: Screen share audio should be streamed to vMix as a persistent ingest source, identical to how speaker audio is handled (independent of the active scene status).
2. Audio/Video Desynchronization (PRIMARY ISSUE)
The integration of vMix introduces a massive A/V offset of approximately 500ms.
Root Cause: Zoom defaults to the direct audio feed from the presenter/source instead of using the processed audio return from vMix.
Impact: While video and audio are perfectly synced within vMix, the attendee hears the "raw" Zoom audio nearly 0.5s before the processed vMix video arrives. This occurs both with and without Production Studio active.
Requirement: An option to force Zoom to prioritize the vMix audio return as the master for the webinar output.
Current Workaround and Limitations
To maintain production quality, we are forced to use a workaround:
Presenters join a separate, private Zoom Meeting.
vMix captures this meeting and processes the signals.
The vMix output is sent via a physical Capture Card (or NDI) to a separate Host PC running the actual Webinar.
Major Drawback: Since presenters are in a separate meeting, they have no access to Webinar interactive features (Chat, Q&A, Polls), which significantly degrades the event quality.
optional but to limited: only use Production Studio
And closing on a good note:
If you only achive 5fps while screen sharing and only see a greyd out "optimize for video" option .
We identified why the higher frame rate is always greyed out (in Webinars) -
• UI Constraints: The "Optimize for Video Clip" toggle is only available when sharing permissions are set to "One person at a time."
this is NOT a default setting and has to be set manually
