whay
#1 Posted : Wednesday, January 7, 2026 8:45:28 PM(UTC)
whay
Turkey
Hello
I hope you are well.
I have a new generation JVC camera. I connected it to the local network.
When I type 192.168.1.88 and port 80 in the browser and enter the username and password, I can access its interface.
How can I transfer the image from this camera to vMix?
jet
#2 Posted : Sunday, January 11, 2026 12:54:04 AM(UTC)
jet
Was thanked: 40 time(s) in 38 post(s)
Hello.
Would really help if you would give the exact camera model..
whay
#3 Posted : Sunday, January 11, 2026 7:22:56 AM(UTC)
whay
Turkey
JVC GY-HM200E
Peter1000
#4 Posted : Sunday, January 11, 2026 8:48:27 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
I believe this camera can only do RTMP, not SRT.
vmix can only receive RTMP via the VLC plugin as client.
OBS has an RTMP server plugin and should be able to receive your camera.
from there you can send the signal to vmix over OMT or NDI.
or you install the open source RESTREAMER, to decode your camera and send it to vMix
elvis55
#5 Posted : Sunday, January 11, 2026 9:01:11 PM(UTC)
elvis55
Switzerland
The Stream input supports adding IP Cameras and Streaming Servers that support the RTSP,
https://www.vmix.com/help24/index.htm?Stream.html
whay
#6 Posted : Tuesday, January 13, 2026 2:44:25 AM(UTC)
whay
Turkey
hello
I can open the camera in the browser.
IP address: 192.168.1.88 Port: 80
The Vmix computer's IP address is: 192.168.1.191
I can't get a picture.
elvis55
#7 Posted : Tuesday, January 13, 2026 4:24:13 AM(UTC)
elvis55
Switzerland
The standard RTSP (Real-Time Streaming Protocol) port is
554 (TCP/UDP), but it is often blocked by firewalls, which is why it is sometimes changed (e.g., to 8554 or another port) and must be forwarded via a router for remote access (port forwarding). RTSP controls media streams (such as video from IP cameras) using protocols like TCP for control and UDP for the actual data flow (via RTP/RTCP).
elvis55
#8 Posted : Tuesday, January 13, 2026 6:35:16 AM(UTC)
elvis55
Switzerland
To set up the JVC GY-HM200E for RTSP,
Connect the camera to the network (LAN/WLAN/LTE), access the web interface via your browser, activate the network menu under System > Network, configure the network connection (DHCP recommended), go to Network > Settings > Live Streaming Set > Server and select a server (e.g. Server 1), set the type to RTSP, enter the stream name, select resolution/bitrate and activate live streaming.
Step-by-step instructions:
Establish network connection:
Connect the camera to a supported USB Ethernet adapter (LAN) or Wi-Fi/LTE to get an IP address.
Go to System > Network and turn it on to "On".
Use the Connection Setup > Wizard to configure the Ethernet connection (DHCP recommended).
Access the web interface:
Find the IP address of the camera in the network status of the camera.
Enter this IP address in your web browser to open the camera interface.
Make live streaming settings:
In the web interface, navigate to Network > Settings > Live Streaming Set > Server.
Select an available server (Server1, Server2 etc.).
Set the type to RTSP.
Enter a stream name (e.g. "jvc") – this must match exactly with the last part of the target URL.
Set resolution (e.g. 720p) and bit rate (e.g. 3.0M), observe the restrictions for simultaneous streaming and recording.
Activate Live Streaming.
Start streaming:
You can use the streaming function to take a button on the camera to start the stream.
Enter the full RTSP URL (e.g. rtsp://IP_ADDRESS_IHRER_KAMERA:554/live/stream1) in your streaming software (such as VLC or OBS) to receive the stream.
See also:
Jvc gy-hm200 stream
https://forums.vmix.com/...7190-Jvc-gy-hm200-stream
