Tomiz
#1 Posted : Monday, December 22, 2025 9:21:53 PM(UTC)
Tomiz
Czech Republic
My setup runs outputs A-F as individual microphones, and G as combined processed audio. I've been recording all 14 channels into an .mp4 file, though I relied on the separate .wav file for audio.
After updating to 29.0.0.41, the same configuration throws up the following error: This format does not support more than 6 Audio Channels.
This is, of course, fixed if I switch the Audio from ABCDEFG to Master, or MAB, but then I lose the individual microphone audio. Switching to .avi is not viable for me due to file size. The configuration has not changed except for the update, the preset is the same as it's ever been.
So how did this happen? Is there a way I can record all my tracks in .wav while still keeping the .mp4 video format? Or do I need to revert to a previous version of vMix?
Googling did not provide much of anything, any insight is much welcome, thanks!
#2 Posted : Tuesday, December 23, 2025 1:19:18 AM(UTC)
@ Tomiz
.MP4 has always only supported a maximum of 6 Audio Channels.
In previous versions of vMix, the error message was only generated on regular recordings but not on MultiCorder recordings, not because more than 6 channels was supported, but likely an just oversight which was fixed in vMix 29.
(if you previously tried to record more than 6 channels with the MultiCorder, no audio was recorded at all, which of course is very problematic when no error or warning was issued)
Tomiz
#3 Posted : Tuesday, December 23, 2025 6:50:13 AM(UTC)
Tomiz
Czech Republic
Originally Posted by: IceStream Go to Quoted Post
@ Tomiz
I am not interested in .mp4 supporting more than 6 audio channels, I want the old functionality come back. I appreciate that vmix now warns you about the format's limitations, but it no longer allows me to record .mp4 video with .wav audio. Basically an error has removed a function of vMix I relied on. Is there a way for me to record lossy video (20mbps ish) with all audio channels now? Is appears to be gone, because the error stops me instead of just recording as before.
#4 Posted : Tuesday, December 23, 2025 8:56:32 PM(UTC)
Was thanked: 4801 time(s) in 1648 post(s)
We will work on an update to try and work around this as we have seen a few users get stuck by this.
The problem is the audio is completely unusable in MP4 when using more than 6 channels, so we roll back to that broken functionality.
On the other hand allowing WAV recording while limiting the audio channels in the accompanying MP4 is not currently a feature in vMix so it's something new we will need to add.
No ETAs at this stage on when this might be.
Tomiz
#5 Posted : Tuesday, December 23, 2025 10:55:34 PM(UTC)
Tomiz
Czech Republic
Thank you so much for the explanation and for the time you took to respond!
I will look into downgrading to a previous version then, as there appears to be no other way I can maintain smaller files at 20mbps quality, and also all the audio channels.
Justingonz
#6 Posted : Monday, January 5, 2026 12:10:45 AM(UTC)
Justingonz
I just want to add that Im also having this issue, but I would also like to ask a question.
OBS allows 6 tracks of audio on MP4 recordings, and they're stereo which would make it 12 audio channels. Is it possible to look at how their pipeline works through the GitHub project and integrate that process into vMix?
Im completely ignorant in software development so I can understand if this is just not at all possible.
