BroadKast
#1 Posted : Wednesday, December 17, 2025 3:38:07 AM(UTC)
BroadKast
The PTZ positioning button cluster (up, down, left, right + 4 diagonals also has a center button.
Touching this button (VERY easy to do accidentally) completely zooms out the camera (at least it does this with my AViPAS camera) and "centers" it. Quite jarring in the middle of a broadcast.
A setting that completely disables this center button button would be welcome.
It might be as "simple" as adding a second PTZ layout where this button is not included.
Thank for listening!
#2 Posted: : Wednesday, December 17, 2025 5:00:57 AM(UTC)
Any button be it a onscreen one or hardware controller can be pushed accidentally!
Create your own "simple" controller using the vMix Shortcut functions, could be done using a web interface, a streamdeck etc
In the case of a hardware controller rip out the center button
BroadKast
#3 Posted : Wednesday, December 17, 2025 5:31:53 AM(UTC)
BroadKast
@doggy - agreed, but it's just too easy to push that particular button, which is in the middle of a closely-spaced cluster of buttons. A checkbox to disable this in the PTZ window, for example: at the bottom of that window above "Always show thumbnail in input preview," would work, and would be hard enough to deselect unintentionally. It could be labeled "Disable center PTZ position button."
Indeed, checking that box would ideally make that center button disappear entirely in the UI.
#4 Posted : Wednesday, December 17, 2025 5:45:26 AM(UTC)
What i dont understand why even use that cluster during a broadcast in the first place , especially as it seem critical in your operation and use
The beauty of vMix is the fact that one is not stuck to being controlled by what vMix has provided but can easily be customized by the use of the functions through controllers, scripts and even custom external applications
IMO get a streamdeck (no need even for companion), define your keys ,add some nice icons, and position them to your liking. due to tactile operation you wont even have to look where you are pressing
https://www.rocosoft.com...with-elgato-stream-deck/
tnorrell
#5 Posted : Wednesday, December 24, 2025 4:25:17 AM(UTC)
tnorrell
Was thanked: 13 time(s) in 10 post(s)
vMix allows you to create new Inputs based on the current PTZ settings. You can even control the speed of the head movements and zoom indipendantly. you could create inputs for each of your desired locations, and then never touch the built in PTX buttons. if you're honestly tracking a subject with constant adjustments, then i HIGHLY encourage you to get a $20 wired usb xbox controller off amazon and use it control your PTZ.
vMix Documentation about joysticks/shortcuts
https://www.vmix.com/hel...PTZControlShortcuts.html
vMix YouTube video about joysticks/shortcuts (start at 7:35)
Roy Sinclair
#6 Posted : Thursday, January 15, 2026 8:15:28 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Good idea but if you have the wandering speaker problem and you don't have dedicated camera operators for each camera also consider updating to the new generation of cameras that have "AI" tracking of subjects. I have an Osbot Tail Air just for following our preacher as he wanders that's usually good enough to follow him to his next location while we frantically point one of the other cameras to that new location and another camera keeping a wide view of the stage (and part of the audience) as a second alternative. Usually by the time he stops we have a manual camera on him and the camera operator (in charge of five cameras) is ready to manually follow him if needed.
Guest (4)
