Markmumc
#1 Posted : Tuesday, December 9, 2025 5:48:45 AM(UTC)
Markmumc
At church, we had one computer displaying content on the local screens and one computer running vMix for streaming to the world. PTZ and stream control cues were sent to vMix over the network from the first computer. Life was good. To cut costs, one new computer was purchased to replace the two old computers - both applications run on the same computer and provide the same functionality. However, the MIDI cues are not working. Since the big change was hardware, I believe the issue is configuration.
Does anyone know how to setup vMix to process MIDI commands from another application rather than from another device?
Any information, insights, etc are truly appreciated.
mavik
#2 Posted : Tuesday, December 9, 2025 7:30:03 PM(UTC)
mavik
You would need some bridge between Midi and vMix. Years ago I did a demo of how this could work. Maybe you can take away something.
Markmumc
#3 Posted : Wednesday, December 10, 2025 3:27:47 AM(UTC)
Markmumc
With both applications running on the same PC, wouldn't Windows 11 provide the bridge?
I need configuration information for the case where the MIDI shortcuts are internally generated in the PC - not from an external device.
mavik
#4 Posted : Wednesday, December 10, 2025 6:47:32 AM(UTC)
mavik
For a control surface you could use touchOCS. It is widely supported.
Roy Sinclair
#5 Posted : Thursday, December 11, 2025 9:03:06 AM(UTC)
Roy Sinclair
Was thanked: 29 time(s) in 25 post(s)
Have you installed RTP-MIDI? I'd bet you had that on the old systems passing the MIDI commands between them.
Markmumc
#6 Posted : Thursday, December 11, 2025 9:06:14 AM(UTC)
Markmumc
Yes, a bridge is needed. We had been using rtpMIDI, but it did not get reconfigured for the new hardware configuration. Reconfiguring rtpMIDI using localhost and the application port number made it work.
Guest (5)
